Latest: jackrox1992
Overall: 17186
Online Now [742]:
Visitors: 741
Today: 166216
Total: 147876848
Forums › The Car › 206 Problems › rev counter
rev counter
steffan2475
PostPosted: Sat Mar 03, 2012 5:17 pm Up
I have just baught a 206 1.4 8v and my rev counter reads 6000 when its idling and sometimes it shows nothing any ideas on what is causing this. What could i do to rectify this fault.
Martind
PostPosted: Sat Mar 03, 2012 5:46 pm Up
You will need to let people know what year the car is, and if it is a Multiplex (chunky indicator/wiper/radio stalks) or a Pre-Plex (Skinny Indicator/wiper/radio Stalks)
steffan2475
PostPosted: Sat Mar 03, 2012 5:52 pm Up
Its a 1999on a t and i think its a multiplex
Martind
PostPosted: Sat Mar 03, 2012 6:03 pm Up
No, on a '99 it would be pre-plexed.
I am not 100% (but someone will correct me) but you may need a new/2nd hand instrument cluster.
This is a common fault, so if you do a search (top left corner) and see what you can find. You will probably be able to solve your problem without putting up your own post
steffan2475
PostPosted: Sat Mar 03, 2012 6:07 pm Up
PostPosted: Sat Mar 03, 2012 6:08 pm Up
What does the live data read?
If you need a new cluster, it needs yo be one of a similar.mileage to yours.
steffan2475
PostPosted: Sat Mar 03, 2012 6:12 pm Up
Live data ? Any ideas were i.could find a second hand cluster.
Hi
Martind
PostPosted: Sat Mar 03, 2012 6:14 pm Up
eBay would be your best bet.
Maybe a local scrapyard?
steffan2475
PostPosted: Sat Mar 03, 2012 6:17 pm Up
Would it matter if i put a different model one in or has it have to be a glx one like the one that's on the car at the moment ?
Martind
PostPosted: Sat Mar 03, 2012 6:23 pm Up
It doesn't matter too much, but if you get one from a lower spec car it might not have some of the functions (i.e Rev Counter/Oil Pressure Guage) I don't know what spec comes with what so you will have to look that up yourself!
As long as it is from a Preplexed one, then it should be fine
steffan2475
PostPosted: Sat Mar 03, 2012 6:27 pm Up
Martind
PostPosted: Sat Mar 03, 2012 6:28 pm Up
Not a problem,
Lee will correct me if I am wrong as he knows his stuff.
Don't take what I say as gospel though, until you have double checked (Or Lee tells you!)
craigdmjv
PostPosted: Sat Mar 03, 2012 6:34 pm Up
as long as its from pre plexed has same functions and same plug ect its fine but needs to be around same mileage
PostPosted: Sun Mar 04, 2012 4:10 am Up
Don't forget the mileage!
Also petrol and diesel
mdstone
PostPosted: Tue Mar 06, 2012 2:58 am Up
I had an erratic rev counter once which also did nothing at times and it was down to a cracked ABS Ring.
Peugeot 206 GTi
