Posted: Tue Mar 06, 2012 2:12 am |
You don;t even need to take the gearbox out to change the synchros...stil not a job for a fast fit centre...
Posted: Tue Mar 06, 2012 8:12 am |
Anybody ever changed the synchros on one of these boxes? Just looking on servicebox now the Syncro hub is £23 including vat.
Posted: Tue Mar 06, 2012 12:34 pm |
LeeThr wrote: |
Seabook wrote: |
synchro is cheap.... |
How cheap? How big a job is it to change? |
last time i check each ring is about 20-30 quid.
Posted: Tue Mar 06, 2012 12:39 pm |
LeeThr wrote: |
Anybody ever changed the synchros on one of these boxes? Just looking on servicebox now the Syncro hub is £23 including vat. |
not that difficult if you can drop the box and re-fit it.
i got a detail guide with pics.
will post it once i got back home from work.
Posted: Tue Mar 06, 2012 2:04 pm |
Posted: Wed Mar 14, 2012 8:36 pm |
Just a thought, Could it be an issue with the clutch not dissengaging properly? Hydrolics need bleeding?
