Latest: Worthy967
Overall: 17143
Online Now [286]:
Visitors: 285
Today: 26681
Total: 115801621
Forums › The Car › 206 Problems › Headlights
Headlights
bseedhouse
PostPosted: Wed Mar 07, 2012 3:37 am Up
So I changed the light bulbs on my car and they stopped working but they started working but they've suddenly stopped again my battery is flat would this stop my headlights working?
Benji\'
Martind
PostPosted: Wed Mar 07, 2012 3:39 am Up
Yes if your battery is flat nothing on your car will work
bseedhouse
PostPosted: Wed Mar 07, 2012 3:54 am Up
Other bits work but wouldn't start dipped beam worked but when I turned full beam on it all cut out?
Benji\'
Martind
PostPosted: Wed Mar 07, 2012 3:56 am Up
Have you got the engine running when your doing this?
bseedhouse
PostPosted: Wed Mar 07, 2012 3:58 am Up
No ad the battery and it won't start...
Benji\'
Martind
PostPosted: Wed Mar 07, 2012 4:00 am Up
I would say get the engine started and then try, Could i ask is this your 1st car?
bseedhouse
PostPosted: Wed Mar 07, 2012 4:01 am Up
Yeah it is
Benji\'
Martind
PostPosted: Wed Mar 07, 2012 4:06 am Up
Get a new battery on it or get it jump started. If you jump start it then go for a drive
Martind
PostPosted: Wed Mar 07, 2012 4:07 am Up
Plus it will do that as your battery is flat
Plus
If i was you i would go and get a 206 haynes manual very helpful if its your 1st car
www.ebay.co.uk/itm/Peu...19ce686fb7
bseedhouse
PostPosted: Wed Mar 07, 2012 4:13 am Up
ok so they should work once i jump start my car?
Benji\'
Martind
PostPosted: Wed Mar 07, 2012 4:14 am Up
Yes
bseedhouse
PostPosted: Wed Mar 07, 2012 4:16 am Up
Ok perfect ill jump it when I get home...however other bits of electrics were working but just not my headlights? does that make sense...
Benji\'
Martind
PostPosted: Wed Mar 07, 2012 4:27 am Up
Yes that makes sense, As your battery still got abit of life in it just not alot to start it or to use all your lights, If your gotta jump start it make you take it on a long drive or leave it running for a bit
bseedhouse
PostPosted: Wed Mar 07, 2012 4:36 am Up
okay cheers man ive been worrying that ive brocken something! ahah
Benji\'
20619d
PostPosted: Wed Mar 07, 2012 4:39 am Up
mine did this when was sat in garage for 5weeks getting rebuilt. once battery is charged it may be worth gettin batt checked that it holding its charge as sum times they will be funny once been dead once
