Latest: tbafonso
Overall: 17130
Online Now [363]:
Visitors: 362
Today: 30084
Total: 102767060
Forums › The Car › 206 Problems › failing an MOT on emissions now what ? :(
138Andy
PostPosted: Fri Mar 09, 2012 3:25 pm Up
Heyhey
my car failed the MOT yesterday on emissions
im unsure what else i could do it drop them i gave it a full service and even bought a new cat but the results were
FAST IDLE SPEED ( Min-2000 Max-3000 ) Actual Reading 1646 = FAIL
FAST IDLE CO % ( Max-0.30 ) Actual Data 1.61 = FAIL
SECOND FAST IDLE CO ( Max-0.30 ) Actual Data 1.19 = FAIL
IDLE CO% ( Max-0.50 ) Actual Data 3.19 = FAIL
Sad
PostPosted: Fri Mar 09, 2012 3:26 pm Up
What did the garage suggest?
138Andy
PostPosted: Fri Mar 09, 2012 3:27 pm Up
he didnt he just mugged me off saying its like my exhaust is f****d but i fitted the new one 2 days before the mot and iv been back to the shop and they say its fine :/
iainlovatt
PostPosted: Fri Mar 09, 2012 3:31 pm Up
put expensive v power fuel in it drive it for 1 hr before taking it back to him and get him to retest it, that should do the trick! Very Happy
(My Garage)
Alex90
PostPosted: Fri Mar 09, 2012 3:32 pm Up
diesel or petrol?
i bought liqui moly injectors cleaner and she pass it straight thru
DIESEL POWER!!!
138Andy
PostPosted: Fri Mar 09, 2012 3:39 pm Up
petrol 2.0l gti
twitch169
PostPosted: Fri Mar 09, 2012 3:40 pm Up
put in some petrol magic and some higher octane fuel and thrash the balls off it down a motorway should clean the crap out works for me and other cars ive had
peugeot 1.6 xs lowerd with black 15\" alloys custom chrome grill painted red dash and trim
138Andy
PostPosted: Fri Mar 09, 2012 3:55 pm Up
sweet cheers its in for a retest next weekend so fingers crossed Smile
PostPosted: Fri Mar 09, 2012 4:09 pm Up
Genuine Cat? For emmision failure i would say the cat is at fault, especially a cheaper one. any engine lights? When was the car last serviced?
PostPosted: Fri Mar 09, 2012 4:12 pm Up
Fit a decent aftermarket exhaust and take the car to a garage that will overlook exhaust emissions!
jimm
PostPosted: Fri Mar 09, 2012 4:25 pm Up
take it to a different mot garage
do\'nt know alot
138Andy
PostPosted: Fri Mar 09, 2012 4:36 pm Up
might have to make friends with some one who can just pass me a mot Razz
PostPosted: Sat Mar 10, 2012 3:00 am Up
did they check the O2 sensor at all?
gazza82
PostPosted: Sat Mar 10, 2012 5:35 am Up
Yes, it's likely your lambda/o2 sensor is shafted ... was it disturbed when you had the new exhaust fitted?
Our 206CC 2.0 has two ... one pre-cat, one post-cat ... but until I get PP working I can't tell which is screwed .. one is, the code reader I have tells me!
138Andy
PostPosted: Sat Mar 10, 2012 8:19 am Up
iv been to see him today he said bring it in next weekend for the retest and he will adjust the readings for a pass Smile
