Latest: ArtistKS
Overall: 17145
Online Now [98]:
Visitors: 97
Today: 20118
Total: 116053856
Forums › The Car › 206 Problems › ECU wiring 2.0hdi
ECU wiring 2.0hdi
ej2_sir
PostPosted: Sat Mar 10, 2012 12:11 pm Up
finished repairing my axle on new car and was just having a poke round the engine bay checking fluids etc. I noticed 2 random wires (blue/black stripe and white) coming from the ecu not in a plug? These are then bullet connected to red and beige wires? Now Im guessing this is not regulation Peugeot wiring so any ideas? Ive not got the wiring diagrams?
2002 206 2.0hdi
ej2_sir
PostPosted: Sat Mar 10, 2012 12:14 pm Up
apologies for pic size!!!!
2002 206 2.0hdi
PostPosted: Sat Mar 10, 2012 12:32 pm Up
Do they actually go into the ECU or to the relay underneath?
If they go into the ECU, then someone has been drilling holes!
ej2_sir
PostPosted: Sat Mar 10, 2012 12:43 pm Up
someones been drilling holes as they go into the plastic! Do you recon its somekind of ebay resister style wiring? Ive got no idea why someone would do this? most people would take off existing wires? any thoughts?
2002 206 2.0hdi
PostPosted: Sat Mar 10, 2012 1:04 pm Up
Where do they go?
Do you have an aftermarket alarm?
ej2_sir
PostPosted: Sat Mar 10, 2012 1:08 pm Up
No after market alarm Im aware of. Those 2 wires are bullet connected to a redwire and a beige wire that appear to follow down with the rest of the loom? Im a bit blind with this one as I dont have any wiring diagrams for the car so really apreciate the help
2002 206 2.0hdi
PostPosted: Sat Mar 10, 2012 1:09 pm Up
Can you see any numbers printed on the wires?
PostPosted: Sat Mar 10, 2012 1:13 pm Up
Do you have cruise control fitted? or IMMO removed?
ej2_sir
They tuck down by washer bottle so its difficult to see. there's not alot of slack so dont wanna pull to hard. there's no numbering on the blue/white wires protruding from the ecu
2002 206 2.0hdi
ej2_sir
PostPosted: Sat Mar 10, 2012 1:15 pm Up
No stalk controls for it? Is there any way to check via Vin number etc?
2002 206 2.0hdi
PostPosted: Sat Mar 10, 2012 1:17 pm Up
Peugeot Service Box Wink
FREE sign up or ask someone else with access
PostPosted: Sat Mar 10, 2012 1:18 pm Up
No point checking via vin number as it won't have been standard, so won't be listed.
If you have it, it'll be a long thin stalk underneath the indicator one.
Just open the ECU up and see what they connect too.
ej2_sir
PostPosted: Sat Mar 10, 2012 1:28 pm Up
Ill have a look tomorrow and see if I can trace the wires a bit more and update. It seems to run ok (apart from indicators stop working, lights flash, airbag light on..... Wink )
2002 206 2.0hdi
PostPosted: Sat Mar 10, 2012 1:31 pm Up
Com 2000 unit Laughing
skinny
PostPosted: Sat Mar 10, 2012 1:32 pm Up
well if everything else seems ok i wouldnt mess around too much
as the saying goes "if it aint broke. dont fix it"
Pug 206 1.4 Hdi
Pug 206 Gti 138
