Online Now [440]:
Visitors: 439
Today: 157731
Total: 146612629
Forums › The Car › 206 Problems › One tyre on a lean
One tyre on a lean
deebee
PostPosted: Fri Mar 09, 2012 9:47 am Up
Went driving today, nothing really happened, but when i got back my mates pointed out my back passenger side wheel was at a angle? it was worse then the other side and i remember having a thread problem with that tyre also. Could this cause it? Plus I wondered if camber actually helped the car Smile
Breaking 2.0 hdi with ps and gti bits
Big_Rich180
PostPosted: Fri Mar 09, 2012 9:52 am Up
Your rear axle could be shot or its been bashed into a curb at some point dependent on if the wheel is in at the top or bottom, could be other things too, take it to a garage.
PostPosted: Fri Mar 09, 2012 10:20 am Up
Sounds like the axle is shot and needs replacing.
If I remember right you can't get camber on the 206
Big_Rich180
PostPosted: Fri Mar 09, 2012 10:22 am Up
Not on the rear you cant.
Rob2859
PostPosted: Fri Mar 09, 2012 11:08 am Up
I bet you can if you bend the axle into a banana like my made did on his saxo jumping it at 70mph DOH!!!
deebee
PostPosted: Mon Mar 12, 2012 10:43 am Up
Sorry guys, i haven't replied but how much could that be to replace?
Big_Rich180
PostPosted: Mon Mar 12, 2012 10:45 am Up
Or if you go sideways into a roundabout Laughing Wink
Probably between £300-£600 for a refurb or over a grand for a new one at pug (although that was for a 180).
Check fleabay.
deebee
PostPosted: Mon Mar 12, 2012 10:52 am Up
I haven't done either, i haven't jumped at 70mph nor hit anything and its the other way round its not the bottom in its the bottom out and top goes in as if something has hit it at the top?
Big_Rich180
PostPosted: Mon Mar 12, 2012 10:53 am Up
We weren't saying you had Wink
deebee
PostPosted: Mon Mar 12, 2012 10:58 am Up
nah but I've had the car for about 7 months and only just noticed it Sad
Big_Rich180
PostPosted: Mon Mar 12, 2012 11:03 am Up
The thing is i wouldnt expect the wheels to point in towards the bottom if the bearings in the axel were shot, garage time me thinks.
deebee
PostPosted: Mon Mar 12, 2012 7:14 pm Up
Cheers Rich
rick-gti
PostPosted: Tue Mar 13, 2012 3:10 am Up
My gti is the same wheel is leaning in at the top, jacked the car up and found loads of play at 12 and 6 Sad
Im breaking my gti soon as the beam looks to far gone to replace. Iam lucky as i have another gti that im building.
clio 197sport owner
