Posted: Sat Mar 10, 2012 11:16 am |
Why didn't Peugeot engineer the design of the gearbox to something a bit better with the later 206 models? The gearbox in the 180 is just as sloppy as the gearbox in a 1999 LX. That was my first surprise when I changed vehicles, just the same crap gearbox, the feel is better but has problems going into 1st and 2nd at times as the same as the old hatchbacks.
Everything else pretty much has improved nicely.. if I can get smooth 1st and 2nd gear changing then it would be a whole lot nicer car to drive!
Posted: Sat Mar 10, 2012 12:57 pm |
Peugeot gearboxes have never been that good, if its that bad maybe something is wrong possibly the clutch ?
Posted: Sun Mar 11, 2012 3:48 pm |
I don't know if all 206's are like the one I've driven, but the gear changes felt about as tight as a chinese guy shagging Jordan.
Posted: Sun Mar 11, 2012 4:50 pm |
Yeah, all Peugout and Citroens have the same crappy gearshift
(Except the C1 and 107)
Really does let the car down, which is a bit of a shame but as long as it selects gears, all well and good!
Posted: Sun Mar 11, 2012 6:18 pm |
I don't know if they make them for the 180 but you may want to try upgraded gear linkages
Posted: Mon Mar 12, 2012 12:34 am |
180 use cable linkage
Posted: Mon Mar 12, 2012 6:21 am |
Seabook wrote: |
180 use cable linkage |
Later MA & BE gearbox on 206 also use a cable set up, no idea why PSA bothered to change it for the 206
Posted: Mon Mar 12, 2012 6:23 am |
Martind wrote: |
Thats because the C1 & 107 use a TOYOTA engine & gearbox, the electrics are all Toyota as well.
Only things PSA on those ( apart from Peugeot / Citroen badges ) are the diesel engine, the wing side repeaters & the seats.
Posted: Mon Mar 12, 2012 3:09 pm |
MrBSI wrote: |
Martind wrote: |
Only things PSA on those ( apart from Peugeot / Citroen badges ) are the diesel engine, the wing side repeaters & the seats. |
Is that the reason why peugeotsport didn't use 107 in rallying?
never know that before
Posted: Mon Mar 12, 2012 3:11 pm |
There good little cars & whichever badge there wearing they hold there money well on the 2nd hand market.
Had a 107 loan car for a week, couldnt fault it.
Posted: Mon Mar 12, 2012 3:12 pm |
MrBSI wrote: |
Had a 107 loan car for a week, couldnt fault it. |
i am surprise with your comment!
Posted: Tue Mar 13, 2012 9:04 am |
Can be improved no end if the Control arm nylon ball is worn and the pin in the selector gearbox arm is replaced.
| Cars: 03 206 Look 1.4 HDi & 02 206 Style 1.4 HDi | |
