Latest: tbafonso
Overall: 17130
Online Now [320]:
Visitors: 319
Today: 20122
Total: 104432322
Forums › The Car › 206 Talk › 206 gti 137 cambelt
206 gti 137 cambelt
Go to page Previous  1, 2
gazza82
PostPosted: Wed Mar 14, 2012 8:06 am Up
rick-gti wrote:
I did think of using bolts or allen keys. As long as they are tough and fit i cant see why they wont work. Does anyone no what repositioning the flange means?
The "flange" is the crank pulley. You should only have to move that if the pulley doesn't line up with the pin/locking tool and the cams are locked in place too. I didn't have to touch mine ... it was fine.
rick-gti
Thats similiar to the one i have, how did you tension yours? Did you have the correct tool?
clio 197sport owner
gazza82
PostPosted: Wed Mar 14, 2012 8:10 am Up
Long allen key! Smile No room for small socket and hex, etc
rick-gti
PostPosted: Wed Mar 14, 2012 8:14 am Up
Im doing mine with the engine out so got plenty of room Very Happy On that how to it says to use a special tool to tension the tensioner while you tighten the nut.
clio 197sport owner
gazza82
PostPosted: Wed Mar 14, 2012 4:08 pm Up
Just used an allen key to hold it then tweaked the locking nut. Once it didn't move I could then tighten it properly.
With the engine out it should be a piece of cake ... and you will have less cuts than me probably!!
rick-gti
PostPosted: Thu Mar 15, 2012 11:43 am Up
Ordered me gates timing belt kit and water pump today. Looks pretty straight foward to do then. Will update in my wip when I do it.
clio 197sport owner
Page 2 of 2
