Online Now [1033]:
Visitors: 1032
Today: 207229
Total: 146351996
Forums › The Car › 206 Problems › alternator ?
alternator ?
lisa206
PostPosted: Fri Mar 16, 2012 7:04 am Up
My 206 cuts out like seconds after being started, sometimes struggles to start. Sometimes it cuts flat out when I dip the clutch.
My dash lights all constantly dim then go back to normal in the car.
Is this alternator ?
LISA 206 180
martinius88
PostPosted: Fri Mar 16, 2012 7:16 am Up
Could be alternator, do the headlights go dim aswell and then bright when you rev? But im not 100% sure this would cause it to cut out... although im probably wrong, but sounds like alternator. Somebody else should be able to clarify.
206 2.0 GTi 138, Eibach: Pro-Kit, torsion bar adjusted, ULTRA angel eyes, Black Lexus rear lights, LED side indicators, Scorpion Cat back exhaust system, K&N Panel filter, theloudest.com speakers fitted all round, Sony HU.
Ibiza Cupra 1.8T 20V, JabbaSport Stage 2 Map, K03s Turbo, Forge 008 re-circ Dump Valve, N249/N111 bypass, H&R Lowering Springs, Forge FMIC. 225BHP @ 1.0 Bar. 0-60--5.6s, 1/4mile--14.2
My Old 206 GTi: www.206info.co.uk/Foru...39589.html
New Car - Ibiza Cupra: www.206info.co.uk/Foru...tml#530454
-Dave-
PostPosted: Fri Mar 16, 2012 7:53 am Up
Trade Rating: +36
Could be a earth strap.
Ex 206 Owner.
Bummers
PostPosted: Fri Mar 16, 2012 8:31 am Up
When you say struggles to start, does the starter motor turn over really slowly?
Need to get a multimeter across your battery really, it would tell you straight away if its alternator or not.
2003 206xsi 1.6 16valve
