Online Now [1023]:
Visitors: 1022
Today: 193459
Total: 148950964
Forums › The Car › 206 Problems › FK Angel Headlights
FK Angel Headlights
Aaron888
PostPosted: Fri Mar 16, 2012 5:41 am Up
Hi, I have bought a set of Smoked Angel Headlights for my 206, When i first purcahsed them it said 2004 which is the year of my car .. had them fitted by my local garage and people started flashing at me when they were on .. few days later i took it to the garage to see what was wrong and they didnt allign them correctly because they couldnt .. i done some research and found out that the headlights are made for a 2003 model ..
is there any chance i can get these alligned at all?? Embarassed i cant return them as i bought them a while back. . and want them fitted!
PostPosted: Fri Mar 16, 2012 5:58 am Up
2003 model doesnt make a difference. They fit all 206's. Dont they have manual adjusters that need aligning?
martinius88
PostPosted: Fri Mar 16, 2012 7:12 am Up
yeah there should be two manual adjusters on each light for height and side to side. easy to sort out, garage should know that though!!
206 2.0 GTi 138, Eibach: Pro-Kit, torsion bar adjusted, ULTRA angel eyes, Black Lexus rear lights, LED side indicators, Scorpion Cat back exhaust system, K&N Panel filter, theloudest.com speakers fitted all round, Sony HU.
Ibiza Cupra 1.8T 20V, JabbaSport Stage 2 Map, K03s Turbo, Forge 008 re-circ Dump Valve, N249/N111 bypass, H&R Lowering Springs, Forge FMIC. 225BHP @ 1.0 Bar. 0-60--5.6s, 1/4mile--14.2
My Old 206 GTi: www.206info.co.uk/Foru...39589.html
New Car - Ibiza Cupra: www.206info.co.uk/Foru...tml#530454
Aar_Im_A_Pirate
PostPosted: Fri Mar 16, 2012 10:00 am Up
They could be LHD models. Any chance the lights are made by depo?
Team: Derv
138Andy
PostPosted: Fri Mar 16, 2012 12:35 pm Up
2 bolts on that back can adjust them with a screw driver Smile
Aaron888
PostPosted: Sun Mar 18, 2012 8:26 pm Up
There are 2 Manual adjusters on each of the headlights but they don't seem to be working when the garage adjusts them .. Any ideas? And there are no screws on the back only 2 holes which r manual adjusters that don't even work .. My current motor adjusters don't even budge them
Aaron
138Andy
PostPosted: Sun Mar 18, 2012 8:58 pm Up
have a look inside the adjusters should be attached to a white piece of plasic fixed to the projector lens ? mine came away when i was fitting my hid's nightmare to reattach them
bloodmeal
PostPosted: Tue Apr 03, 2012 6:38 am Up
Yup, the real answer is you've got to get lucky with angel eyes, one of mine aligns, the other doesn't, even with the manual control. the one that works only does because I've opened it up and repaired the pathetic little white grip that always breaks, even on a gentle bump, ive had a few different types of angel eyes, FK, Junyan etc. they all suffer from this.
