Latest: sparrowdclxvi
Overall: 17139
Online Now [161]:
Visitors: 160
Today: 25304
Total: 113225325
Forums › The Car › 206 Talk › Removing engine, some opinions needed
rick-gti
PostPosted: Tue Mar 20, 2012 3:39 pm Up
Im removing a gti (138) engine and re-fitting it into another gti. The gti im removing it from is not goin back on the road. Would I be best to undo the subframe and drop the engine to avoid damaging the o/s side driveshaft. Ive got to change the cambelt and water pump before I fit it into the other gti. And also which is the best way to fit it? I have never fitted an engine, only ever removed them.
clio 197sport owner
PostPosted: Tue Mar 20, 2012 3:45 pm Up
Take the gearbox off and the shaft out before the engine comes out. The more that comes off it the easier it will be to handle.
PostPosted: Tue Mar 20, 2012 3:51 pm Up
Engine isn't heavy at all, two of you can pick it up and throw it around. Just drain all the fluids out.
Just need a jack and a couple of axle stands to lower it level, and to raise it
rick-gti
PostPosted: Tue Mar 20, 2012 3:59 pm Up
Not worried about weight, have a 5 ton hoist. What I want to no is if I undo the two engine/gearbox mounts and the four bolts holding the subframe can I remove this by lowering it and pulling it foward?
clio 197sport owner
