Latest: tbafonso
Overall: 17130
Online Now [307]:
Visitors: 306
Today: 30144
Total: 104561942
Forums › The Car › 206 Problems › flashing stop light warning
skyguy76
PostPosted: Fri Mar 23, 2012 3:15 pm Up
i have an 04 plate 206 hdis . there is a constant STOP light flashing on the dash and the handbrake warning light is on and the abs light is on
i have replaced the pads and discs today and its still the same .... any idea what the problem could be ?
gti180 wanted
PostPosted: Fri Mar 23, 2012 3:19 pm Up
check the level of the brake oil,if it's on the right level,then you have a problem with your ABS system,you have to get it scanned so that you don't have to guess the cause of the ABS fault.
skyguy76
PostPosted: Fri Mar 23, 2012 3:25 pm Up
brake fluid level is fine . car was just serviced last week
gti180 wanted
PostPosted: Fri Mar 23, 2012 3:54 pm Up
then you have an ABS problem
skyguy76
PostPosted: Fri Mar 23, 2012 5:39 pm Up
perhalps an abs ring ?
gti180 wanted
PostPosted: Sun Mar 25, 2012 2:02 pm Up
why guessing while you can get it scanned and know exactlly what is wrong!!!
DeadEyePaul
PostPosted: Sun Mar 25, 2012 2:08 pm Up
I agree with Timon! If it's flashing stop then it could be serious! If it is your brakes and they fail at 70mph what is your next cause of action? Loss of life?
