Latest: jackrox1992
Overall: 17186
Online Now [300]:
Visitors: 299
Today: 47566
Total: 148428530
Forums › The Car › 206 Talk › heater/fan - whats difference between eco mode and a/c?
Forum Index › 206 Talk
army-joe
PostPosted: Fri Mar 23, 2012 4:24 pm Up
Maybe a silly question but whats ECO mode? I have no hand book. Whats better on fuel? When ever I select auto it goes onto A/C mode
Ash
PostPosted: Fri Mar 23, 2012 4:25 pm Up
It turns off the AC Pump in Eco Mode.
Eco is better on fuel (I thought that would be obvious).
army-joe
PostPosted: Fri Mar 23, 2012 4:36 pm Up
well so did i but why does it automaticly go onto A/C mode then when i switch it on "auto"? Plus the revs dont change when either eco or a/c mode is on
MrZiggerz
PostPosted: Fri Mar 23, 2012 5:03 pm Up
You should notice a tick then it should be slightly higher revs, well it is in mine.
army-joe
PostPosted: Sat Mar 24, 2012 3:33 am Up
Thats what I mean I dont get that and i used to get it in my other 206 when i had it. Maybe it ran out
Ash
PostPosted: Sat Mar 24, 2012 5:59 am Up
If the system is out of gas, it will not turn the pump on to protect itself. So you need to regas the system (if that is the problem).
When you click Auto, it turns on the AC because AC isn't just to cool air. It removes moisture as well (and you do get warm air when you have the AC one). This aids in screen demisting among other things.
army-joe
PostPosted: Sat Mar 24, 2012 7:33 am Up
Nice useful bit of info mate, so as soon as the A/C is on, regardless of temp its using fuel right?
PostPosted: Sat Mar 24, 2012 7:39 am Up
AC does use slightly more fuel BUT running with the AC turned off & opening a window to let in cool air will use more Wink
Ash
PostPosted: Sat Mar 24, 2012 2:43 pm Up
Mr BSI can answer this re. the 206 but on my Audi, the AC Pump only runs at 4c and above.
And in my opinion, I would keep it on constantly as MrBSI said.
rick-gti
PostPosted: Sat Mar 24, 2012 2:54 pm Up
My gti a/c doesnt work wont go ice cold. I have noticed not having the cc on at all its better on fuel. My other gti a/c is ice cold, would that mean it needs re-gassing?
clio 197sport owner
Ash
PostPosted: Sun Mar 25, 2012 3:55 am Up
Yup
Alex90
PostPosted: Sun Mar 25, 2012 5:20 am Up
just i quick question
How much garage gonna charge me for top up my air con,and i think its leaking somewhere,you think its fixable or have to change air con hoses?
DIESEL POWER!!!
army-joe
PostPosted: Sun Mar 25, 2012 7:57 am Up
about 20 - 40 quid
Ash
PostPosted: Sun Mar 25, 2012 11:24 am Up
I doubt its leaking but they do normally require a regas when it hasn't been used for time.
shadow
PostPosted: Mon Mar 26, 2012 5:13 am Up
krap fit do a re-gas for £50 and if it don't reduce temp by 10% no charge is made
206cc 2.0 allure
