Latest: Puggingalong
Overall: 17129
Online Now [352]:
Visitors: 351
Today: 105391
Total: 101617406
Forums › The Car › 206 Problems › ECU wiring 2.0hdi
ECU wiring 2.0hdi
Go to page Previous  1, 2
ej2_sir
PostPosted: Sun Mar 25, 2012 10:44 am Up
Right, was a nice day today so had 5 minutes to whip ECU out and investigate the 'added wiring'. Unfortunatley I still cannot get a wire number off the red and beige wires that the added wires attach to but on opening the ECU they are soldered onto the centre plug on pins A4 and A2. Why the hell they didnt attach to the wires outside of the ecu is beyond me... Any one know what these are allocated to?
2002 206 2.0hdi
PostPosted: Sun Mar 25, 2012 10:58 am Up
Lee might help you with what those pins are for, im guessing something aftermarket has been added sometime, now removed.
PostPosted: Sun Mar 25, 2012 11:49 am Up
Are there any wires or pins coming out of the ECU that aren't attached to anything?
ej2_sir
PostPosted: Sun Mar 25, 2012 12:19 pm Up
no mate. its just those 2 which are non standard. They come off those pins and are drilled out the side of the ecu and then attach to a red wire and a beige wire that go with the rest of the ecu wires into the main loom
2002 206 2.0hdi
PostPosted: Mon Mar 26, 2012 12:31 pm Up
Both are earth wires.
ej2_sir
PostPosted: Mon Mar 26, 2012 1:02 pm Up
top man! I dont suppose you have a hdi wiring diagram and 3 plug ecu pin out available (everyone I found is single plug)? Id like to stip this non standard wiring out but I am still unsure what system it is tied into? Thanks so much for your help so far
2002 206 2.0hdi
PostPosted: Mon Mar 26, 2012 1:04 pm Up
They'll both just go to a earthing point. It'll be to fix a a fault. If you take them off then the car might not start.
ej2_sir
PostPosted: Mon Mar 26, 2012 1:11 pm Up
Fair enough, It just seems a really poor way of doing things! Thanks for your help and clarifying things
2002 206 2.0hdi
PostPosted: Mon Mar 26, 2012 1:30 pm Up
It's better than tapping into existing wires. Direct contact with solder means a better connection.
Only downfall is that they should have wrapped some leccy tape around the wires on the exterior to keep them together and to protect them.
Page 2 of 2
