Latest: Kifi69
Overall: 17183
Online Now [529]:
Visitors: 529
Today: 74565
Total: 144221599
Forums › The Car › 206 Talk › Fault code p0341
Fault code p0341
Forum Index › 206 Talk
nathdavies91
PostPosted: Mon Mar 26, 2012 5:18 am Up
my gti 180 has been running like a bag of s**t took it to the garage and it came up with 2 faults
P0351 - Ignition coil A primary/secondary circit malfunction
P0341 - Camshaft position sensor circuit range/performance
Ive changed the coil pack as the mechanic advised, he told me that it should be ok just changeing that, but im still getting anti poloution fault up and the EML on! its running on all 4 cylinders again now bt it doesnt seem to kick the same as it used to when i drop a gear, what is that sensor for range / performace?? weres it located and how much are they?
sorry if this is a repost but i couldnt find it on the search!
thanks nath
lmilligan
PostPosted: Mon Mar 26, 2012 6:11 am Up
VVT solenoid?
frankaai
PostPosted: Mon Mar 26, 2012 6:31 am Up
Speak to a guy called lee on here he is the man to speak to about fault codes, he helped me out last time i had 4 different fault codes lol
PostPosted: Mon Mar 26, 2012 6:44 am Up
What spark plugs, when were they changed last?
nathdavies91
PostPosted: Tue Mar 27, 2012 5:37 pm Up
Bosch super 4s I replaced them around 2k ago! There's no warning lights atall now, should I just ignor it? Or change the sensor anyways?
