Latest: tebas93089
Overall: 17179
Online Now [120]:
Visitors: 119
Today: 9734
Total: 137975342
Forums › The Car › 206 Problems › ABS light turns on and off randomly
bozmann
PostPosted: Wed Mar 28, 2012 5:04 am Up
Recently my ABS warning light has come on randomly. Took a quick check at the cables and sensors on the wheels, but could not see anything wrong.
I think one of my cv-joints are ready for å replacement, cause i've been hearing some clicking noises while turning.
Could this be the reason?
Norway Calling!
PostPosted: Wed Mar 28, 2012 5:16 am Up
Not sure mate but i have the same issue where sometimes mine will come on after a journey then when i go in the car again it turns off
Martind
PostPosted: Wed Mar 28, 2012 5:17 am Up
It could be a ABS ring, As my old cc did this...
bozmann
PostPosted: Sun Apr 01, 2012 4:58 am Up
So you think its a ABS ring? Took a quick look at the rings, but could not see anything wrong.
Best bet is to change the CV-joint?
Norway Calling!
bozmann
PostPosted: Sun May 20, 2012 5:22 am Up
Still having the problems with the ABS. And its very anoying when im out driving, then suddenly the abs goes bananas when i brake Sad
Is it possible to only change the ABS rings or do i have to change the whole CV-joint?
Norway Calling!
Linkpad
PostPosted: Sun Jun 03, 2012 8:16 am Up
I had similar problem in my MOT the guy fixed it by replacing one of the rear ABS sensors on the ring, no problems since might be the same problem you have ?
Boo
bozmann
PostPosted: Wed Jun 06, 2012 5:36 am Up
Aha! i'm sorry i dont quite understand what you mean by rear ABS sensors? Can you please elaborate?
Help is much appreciated mate! Wink
Norway Calling!
bozmann
PostPosted: Mon Jun 11, 2012 4:31 am Up
Anyone?
Norway Calling!
mtempsch
PostPosted: Mon Jun 11, 2012 8:44 am Up
ABS sensor: The unit that sits on a non-rotating part close to the ring and senses the pulses in the magnetic field as the teeth of the ring goes by it (as the wheel rotates).
There's one at each wheel, so 2 front and 2 rear ones...
If the ABS controller sees fewer pulses from one or more wheel than from others, it knows that/those wheels are rotating slower. No pulses = locked up...
Do a search on Youtube for 'ABS ring' and or 'ABS sensor' and you'll find videos of these items [being changed]
Silvermetallic 2004 206 RC
bozmann
PostPosted: Tue Jun 12, 2012 4:37 am Up
Thanks mate! That cleared it all up for me Wink much appreciated!
Norway Calling!
bozmann
PostPosted: Mon Jul 23, 2012 9:05 am Up
Hi guys! I took my 206 to my local garage, and got a diagnosis on the abs light. And he said that its my rear left ABS sensor thats broken.
I've been looking around ebay, and there is apperantly two different sensors.
ABS SENSOR
Is this the right one?
Norway Calling!
PostPosted: Mon Jul 23, 2012 9:07 am Up
ABS SENSOR
VIN number + Peugeot Service Box will give you the correct part number.
Either sign up for a FREE account or PM me the cars VIN number & ill have a look for you.
public.servicebox.peugeot.com/
bozmann
PostPosted: Wed Jul 25, 2012 8:11 am Up
PM sent Wink
Norway Calling!
PostPosted: Wed Jul 25, 2012 8:17 am Up
VIN number comes back as a Onyx black 206 GTI
Peugeot / Citroen part number for the rear ABS sensor for that 206's VIN is 4545 79
Your GTI has headlamp washers, daytime running lights, heated seats all of which a UK spec GTI never had.
No deadlocks or alarm on your 206 which where standard on a UK spec GTI
Plus you have a electric sunroof.
bozmann
PostPosted: Sun Jul 29, 2012 7:06 am Up
Thanks mate!
Norway Calling!
