Latest: Kifi69
Overall: 17183
Online Now [421]:
Visitors: 420
Today: 50552
Total: 144197596
Forums › The Car › 206 Talk › well priced or not?
well priced or not?
Go to page Previous  1, 2
DeadEyePaul
PostPosted: Thu Mar 29, 2012 6:04 pm Up
I know someone in Daventry,Northampton that can do it for you. He fitted my clutch and changed the oil for me for 100. He is willing to do more work on supply and fit basis (you supply he fit)
kurosagi01
PostPosted: Fri Mar 30, 2012 12:55 am Up
Your better off supplying the parts yourself it be cheaper and then go to a garage to fit them.
Also do 1.4 use coilover or they use dampers/shocks?
PostPosted: Fri Mar 30, 2012 1:05 am Up
ALL 206 use springs and dampers, as standard.
Either can be fitted as an upgrade. All 206s also use the same suspension points. I.e are interchangeable. However, for example, if you buy springs designed for a 1.1 and fit them to a 2.0hdi, they will drop an extra 10-15mm due to the weight of the HDi lump.
marc206
PostPosted: Fri Mar 30, 2012 12:27 pm Up
What are the next best dampers down to Bilsteins?
spike_202
PostPosted: Fri Mar 30, 2012 3:54 pm Up
I had spax on my escort but I've only ever had the B6z on the pug as it was a fit and forget type of mod for me I've had them for around 4 years now and still feel the same as the day they were fitted 2bh
**spike's project**
TEAM:+200bhp
marc206
PostPosted: Sat Mar 31, 2012 12:49 pm Up
Great, thanks
Page 2 of 2
