Latest: cogeim7
Overall: 17185
Online Now [1635]:
Visitors: 1634
Today: 160711
Total: 147059095
Forums › The Car › 206 Problems › car idles horribly and cuts out :(
Adam2061994
PostPosted: Wed Mar 28, 2012 5:21 am Up
my car has been idling weird for a while now, and sounded like it was misfiring, i had a little blowing on the exhaust, fixed that, and i can now here it was misfiring a little, when idling it would be going up and down, sometimes below 800rpm and back up to 1000rpm, but when im driving feels a little sluggish at low rpm but when it picks up its fine no bad noises or anything, the engine management lights came on and got it plugged in and it said adaption mixture and that it was adding and taking fuel away whenever it felt like it, any ideas, its had a new coil pack, spark plugs and everything Sad
206 1.6 owner
dafdavies
PostPosted: Wed Mar 28, 2012 6:24 am Up
what spark plugs has it got in?
Team: If you cant find the tool you need make one
Adam2061994
PostPosted: Wed Mar 28, 2012 6:47 am Up
the ones that are made for the car, bosch i think fella
206 1.6 owner
PostPosted: Wed Mar 28, 2012 6:52 am Up
injectors maybe
Bummers
PostPosted: Wed Mar 28, 2012 12:46 pm Up
Replace the coolant temp sensor, it can cause all sorts of weird symptoms when it's playing up.
2003 206xsi 1.6 16valve
dbspider
PostPosted: Wed Mar 28, 2012 1:01 pm Up
ill watch this with interest
please keep us updated
me my car
DeadEyePaul
PostPosted: Wed Mar 28, 2012 1:04 pm Up
My spiderman sense detects ICV?
dbspider
PostPosted: Thu Mar 29, 2012 12:04 am Up
where is the icv located ?
me my car
Ash
PostPosted: Thu Mar 29, 2012 7:45 am Up
On the air inlet pipe at the top. There is a FAQ somewhere with pictures.
m.killeavy
PostPosted: Fri Mar 30, 2012 7:28 pm Up
Sounds like similar symptoms to my car when throttle body went, intitial research also suggested possible MAP sensor issues?
Hope you get it sorted
206 1.6 Roland Garros
dbspider
PostPosted: Fri Mar 30, 2012 9:11 pm Up
i came apon something when i serviced my car the oter day looking from the front of the car on the firewall top right was where the throttle cable was going to a black box now i noticed that the cable was really really slack so i tightened it up and that seemed to help with the wifes car
me my car
Adam2061994
PostPosted: Sat Mar 31, 2012 8:18 am Up
thanks guys! i think its the idle control valve with what people are telling me, but i will check all the rest of them thanks!:) x
206 1.6 owner
johnuk
PostPosted: Sat Mar 31, 2012 8:29 am Up
when was the plugs last changed is a good starter
my gti problem
keeno
PostPosted: Sun Apr 01, 2012 4:05 am Up
would a faulty idle valve show on a diagnostic machine??
im having the same kinda issues, my revs drop and car cuts out when i break and change to a low gear.
took it to a local gge and they didnt find any faults on the diagniostic machine.
cheers
206 Gti 180
