Latest: tbafonso
Overall: 17130
Online Now [628]:
Visitors: 627
Today: 77372
Total: 103002938
Forums › The Car › 206 Problems › off set washers "torsion bar"
138Andy
PostPosted: Mon Apr 02, 2012 3:03 am Up
got about 2-3 mm movement in the top one but now its just stopped Confused
johnboy1989
PostPosted: Mon Apr 02, 2012 3:20 am Up
Edward wrote:
They go in through the trailing arm - the arm the wheel is attached to.
When knocking the torsion bars out you need to make sure you aren't just pushing the arms off the tube. So the arm needs holding in place maybe with some timber between it and a wall.
When mine came out on mine they came out the other way to how you got the arrows on this pic :S strange isnt it
China Blue 1.6 XS Owner Wink
johnboy1989
PostPosted: Mon Apr 02, 2012 3:21 am Up
Just keep WD40 it up help you out and sooner or later it will come out just takes time.
PostPosted: Mon Apr 02, 2012 5:01 am Up
I suppose the bars can go either way if you are just lowering the back end. My method is enough to remove the torsion bar completely. I'm sure one end is fatter than the other so will only go one way.
138Andy
PostPosted: Mon Apr 02, 2012 6:57 am Up
ill give it a hour if it wont budge then ill buy a blowtorch
138Andy
PostPosted: Mon Apr 02, 2012 9:33 am Up
THE TOP ONES OUT!!
now the task is to remove the squished torx screw :'(
PostPosted: Mon Apr 02, 2012 12:44 pm Up
Just use an old wood working chisel. It will cut into the screw and shift it easily - well it did for me.
138Andy
PostPosted: Mon Apr 02, 2012 12:59 pm Up
the bottom torsion bars not budging had me smashing it for a hour and my dad for a hour after that its seized in the drivers side to its just pushing the arm off ? :/ wont hit backwards or forwards cant even roll it to a garage my wheels are in Birmingham and i only got 1 torsion bar in XD got till the 15th to get this done before im back at work :'( p**sing me off why cant peugeot make anything easy....
PostPosted: Mon Apr 02, 2012 1:51 pm Up
It won't knock the arm off if you put a block of timber between the arm and a solid object.
138Andy
PostPosted: Mon Apr 02, 2012 1:58 pm Up
my car has no wheels and its in the middle of the garden Wink my maa would get moody if i built a wall Wink
what about if i tie wrap it ? got some heavy duty ones ??
138Andy
PostPosted: Tue Apr 03, 2012 3:55 am Up
there out!!!!!!! time to drop this b***h on her a**e Wink
DeadEyePaul
PostPosted: Tue Apr 03, 2012 4:18 am Up
PICTURES! Smile
138Andy
PostPosted: Tue Apr 03, 2012 2:13 pm Up
got no wheels until i pick them up thursday Smile but will upload them soon as Smile
Chris180
PostPosted: Sat Apr 07, 2012 2:22 pm Up
ok i'm in the middle of doing this aswell and i have the bolts and washers out
can some one clearthis up...hitting the top bar from the drivers side and forcing it towards the passenger side is the correct way to be going...and then the lower bar hit from the passenger side forcing it towards the driver side???
2003 aegan blue gti 180 - CatCams 804's camshafts - CatCams vernier pulley - R.S.Tuning remap
Gti 180 Project Thread
PostPosted: Sun Apr 08, 2012 1:58 am Up
That's what the picture says yes. In reality you can knock them either way when just lowering the rear.
Page 2 of 3
