Online Now [513]:
Visitors: 512
Today: 186623
Total: 146641503
Forums › The Car › 206 Problems › Strange Cut Out?
Strange Cut Out?
Bigbenj_08
PostPosted: Tue Apr 03, 2012 6:29 am Up
Hi all,
Hoping you can help here.
I was driving along and slowing down to a coast (probably about 3mph) with the clutch in and the car just cut out. (lost power steering and abs etc).
I'd only started the car about 2 mins prior, so the engine was cold.
I'd had a few idling problems when it was cold - wouldn't hold idle when 1st started from cold, but that seems to be ok now.
But i've also noticed that occasionally if I don't quite give it enough gas when setting off/changing gear, there is a rattle/rumble from the clutch or gearbox.... but I put that down to lazy driving when I'm shattered.
Wondered if my clutch is on its way out, but i've had cluthes wear on me before and this doesn't seem the same.
Sort of lost for ideas here!
Thanks in advance!
Aegean Blue 1.6 16v Sport
Bigbenj_08
PostPosted: Wed Apr 04, 2012 11:48 am Up
Right.. I reckon its the ICV.. could anyone please tell me where it is located on a 1.6 16v 206?
Many thanks
Markzedd
PostPosted: Thu Apr 05, 2012 12:37 pm Up
Think I've got the same problem has you...
Hi,,,,,
Markzedd
PostPosted: Thu Apr 05, 2012 1:13 pm Up
Hi,,,,,
Bigbenj_08
PostPosted: Wed Apr 11, 2012 5:55 am Up
Gah... still doing it Sad
Can't for the lift of me find the sodding ICV.. anyone able to help?
Its still cutting out when cold and dropping revs.
Razor34
PostPosted: Wed Apr 11, 2012 6:10 am Up
Hi,
Use the search field mate - been asked loads of times Very Happy
Ray
Bigbenj_08
PostPosted: Wed Apr 11, 2012 10:45 am Up
Don't worry.. I have! Can't see anything specific to the 1.6 16v... I know where is on a 1.4 and a 1.1 now though Laughing
PostPosted: Wed Apr 11, 2012 12:08 pm Up
As far as im aware you dont have one? (electronically controlled)
Bigbenj_08
PostPosted: Wed Apr 11, 2012 3:28 pm Up
Hmm.. see that would make more sense then and possible stop me going mad! I've been looking on the servicebox and couldn't see one Laughing
Damn, so I guess I'll have to go get it plugged in when I can stump up the reddies.
Why can't car's be simple like in the old days, I'm no good with this electric stuff! Can't wait to move house and get a garage so I can stuff a classic in there!
Cheers though mate.
Bigbenj_08
PostPosted: Tue Jun 05, 2012 7:07 am Up
Slight update to this.. I'm still having issues but now own a 307 haynes manual as it has my engine in it.
I beleive this could be due to a faulty MAP sensor or something to do with the air intake as the engine doens't seem to be getting the required air/fuel mix when cold.
Aside from the MAP sensor, any other sensors I can check/clean/replace that control the air/fuel?
I'll be cleaning the TB and butterfly to make sure that isn't sticking, but it seems fairly clean...
