Posted: Wed Apr 04, 2012 5:12 pm |
I had an issue with reception on my kenwood HU when it was fitted and couldn't get any AM reception at all. Took the radio out, took the aerial cable out and had a look, it was a bit loose in its housing. used a bit of insulation tape to make it more rigid and put it back in and back in the dash, works well now! Also it can sometimes come off as you put the radio back in depending on the room behind it.
| | ![](images/spacer.gif) |
Posted: Wed Apr 04, 2012 5:31 pm |
gibbs- wrote: |
I had an issue with reception on my kenwood HU when it was fitted and couldn't get any AM reception at all. Took the radio out, took the aerial cable out and had a look, it was a bit loose in its housing. used a bit of insulation tape to make it more rigid and put it back in and back in the dash, works well now! Also it can sometimes come off as you put the radio back in depending on the room behind it. |
People still listen to AM radio lol
Posted: Wed Apr 04, 2012 5:32 pm |
do ariels have an earth
Posted: Wed Apr 04, 2012 8:50 pm |
craigdmjv wrote: |
do ariels have an earth |
Yes.
Posted: Thu Apr 05, 2012 3:05 am |
I bought an aerial booster which worked a treat. just plugs inbetween the aerial on the hadunit and you insert the clip into the iso block where there is a 12v ignition feed.
Posted: Wed Apr 24, 2013 5:45 am |
gaffa786 wrote: |
gibbs- wrote: |
People still listen to AM radio lol |
Lol clearly not in my case!
But love a bit of talk sport on the way home from a match and can't get it!
Any ideas? My normal reception is a bit naff but on FM i still pick up the stations
Posted: Wed Apr 24, 2013 6:03 am |
gibbs- wrote: |
gaffa786 wrote: |
gibbs- wrote: |
Any ideas? My normal reception is a bit naff but on FM i still pick up the stations |
AM is still used as an alternative for BBC Lancashire when they are covering 3 games at once. Plus Talk Sport and 5Live are always listened to at the weekend.
Posted: Wed Apr 24, 2013 10:35 am |
Yeah, have to listen to BBC London on way as I can't get any AM stations, thats not good
