Posted: Fri Apr 06, 2012 9:27 am |
Trouble with ceiling light inside.
They will not turn on when I open a door or turn off the car as it should. The switch on the ceiling is set for them to do so, but it does not help. The lights do work for when I change the switch so that they will be constantly on, they do. Have checked the fuse and it's not blown.
The question is: How do I get the lights to turn on when I open the doors or turn off the car? Perhaps it is wrong with the switch?
Many thanks for all your help!
Posted: Fri Apr 06, 2012 9:30 am |
did you try taking the bulb out before? mine did this when i took the bulb out to replace it. but after i put it back on properly it started working how it should. make sure the connectors are clean when its taken off
Posted: Fri Apr 06, 2012 10:12 am |
| gaffa786 wrote: |
| did you try taking the bulb out before? mine did this when i took the bulb out to replace it. but after i put it back on properly it started working how it should. make sure the connectors are clean when its taken off |
Posted: Fri Apr 06, 2012 10:33 am |
considering he posted a couple hours about a central locking problem, guessing the immobiliser or the fusebox, disconnect car batter (search proper procedure for it on forum) and check your fuses inside at the steering wheel and under the bonnet, then reconnect the battery if nothign found and maybe in that time the immobiliser might come to its senses
Posted: Fri Apr 06, 2012 11:48 am |
Thanks again Rob.Be!
I'll try that and hope it "comes to it's senses"! =D
