Online Now [845]:
Visitors: 844
Today: 140808
Total: 146285650
Forums › The Car › 206 Talk › Drive shaft
Drive shaft
Forum Index › 206 Talk
frankaai
PostPosted: Thu Apr 12, 2012 8:13 am Up
Would a passenger side drive shaft fit the middle of the driverside driveshaft on an hdi 2.0? i just bought a passengerside driveshaft and was going to split the driverside one then use it, im just wondering if anyone knows if it would fit? plus would the driveshaft from this car fit mine hdi?
www.206info.co.uk/Foru...44598.html
PostPosted: Thu Apr 12, 2012 9:21 am Up
no
frankaai
PostPosted: Thu Apr 12, 2012 9:25 am Up
no to what question mate? the passenger side driveshaft? is it a different length to the driverside when its split?
PostPosted: Thu Apr 12, 2012 10:16 am Up
once you split the longer shaft in between, i can almost guarantee you will need new bearing before you can put them back together.
so i would just pick up the correct shaft
frankaai
PostPosted: Thu Apr 12, 2012 10:24 am Up
right.... il give it a go later and let you know how i get on, hopefully il not need to replace the bearing, no one has anyone of these driveshafts in the breakers, might have to buy a new one
PostPosted: Thu Apr 12, 2012 10:27 am Up
there is some on ebay, not really cheap though
frankaai
PostPosted: Thu Apr 12, 2012 12:45 pm Up
brought it down to garage got it up on the ramp, took a look and didnt even atempt it, really could not be bothered swapping boots over etc to much of a messy job, i put my mot date forward and il have a hunt for a decent 2nd hand one, does the gti 180 have the same drive shafts as the hdi? plus after more inspection i need a fking rear wheel bearing too lol
PostPosted: Thu Apr 12, 2012 12:51 pm Up
You can ask your question in the original thread no need to make a new one
PostPosted: Thu Apr 12, 2012 1:05 pm Up
some of the 2.0 HDi build share the same shaft as gti and 180gti.
frankaai
PostPosted: Thu Apr 12, 2012 1:34 pm Up
What about the gti137? Someone is breaking one on here
frankaai
PostPosted: Thu Apr 12, 2012 2:26 pm Up
ok..
oldskoolz
PostPosted: Fri Apr 13, 2012 6:05 am Up
just buy the proper shaft, no need to complicate things
Black 206 Gti. Soon to be 2.2
