Online Now [124]:
Visitors: 123
Today: 27368
Total: 138649233
Forums › The Car › 206 Problems › Bonnet won't shut properly!
stg-joker
PostPosted: Thu Apr 12, 2012 12:23 pm Up
Heya there,
Since i've brought my Peugeot 206 the passengers side of the bonnet wont close properly there's a gap between the headlight and the bonnet, i have attached a photo for you lot to have a look and hopefully i can find out what the problem is!!
Many thanks.
Chris Gee
Abzynthe
PostPosted: Thu Apr 12, 2012 12:24 pm Up
East Area Rep - Abzynthe
front of the bonnet looks flat. maybe its slightly out of shape
stg-joker
PostPosted: Thu Apr 12, 2012 12:32 pm Up
wouldnt be bonnet catch/clip or anything?
Chris Gee
PostPosted: Thu Apr 12, 2012 12:40 pm Up
the front of it looks bent slightly, but pull up the bonnet and drop from a decent height, not too high though
Abzynthe
not if you can shut the bonnet and not be able to lift it again without pulling the popper. The latch is in the middle so shouldnt really affect it.
PostPosted: Thu Apr 12, 2012 12:41 pm Up
Do you know the history of the car? The bonnet may have been off before and not been put back on correctly
ARRAN
PostPosted: Thu Apr 12, 2012 12:44 pm Up
Mine sits exactly the same, still to this day do not know why. The metal latch bit on the actual bonnet looks like it has been bent to one side for it fall in place. Also the recess doesn't line up with the badge properly if you look at it head on.
See my project here.
stg-joker
PostPosted: Sat Apr 14, 2012 4:15 am Up
Ahh okay then, I might as well leave it and look into it when i have a bit more time and money maybe!
Thanks for your help on this though.
Chris Gee
138Andy
PostPosted: Sat Apr 14, 2012 5:41 am Up
mine was the same just lean on it its because when fitting doors etc they never sit level car companys just wack it with a rubber mallet to move them into place
