Latest: Puggingalong
Overall: 17129
Online Now [230]:
Visitors: 229
Today: 51439
Total: 100905096
Forums › The Car › 206 Problems › [solved] Alternator fix
Jensen
PostPosted: Fri Apr 13, 2012 2:31 am Up
Soo my alternator on my 1.1 petrol pug is dead Sad just wondering if anyone had any ideas of how to replace one? I've got a rough idea, but was just looking for some more information Smile all answers appreciated Very Happy
PostPosted: Fri Apr 13, 2012 2:45 am Up
Remove the belt, unbolt power cable, unclip other plug. Remove 4 bolts, alternator falls off, refitting is the reverse of removal, bobs your uncle
Jensen
PostPosted: Fri Apr 13, 2012 3:05 am Up
Sounds pretty simple that! Tbh i bottled it after hearing you had to move the power steering pump out the way, left it with a mate for the day seens he knows what he's doing Razz
PostPosted: Fri Apr 13, 2012 3:13 am Up
You dont have to but it makes it easier and the pumps even easier to remove than the alternator.
Jensen
PostPosted: Fri Apr 13, 2012 3:32 am Up
Ohh fair enough, least it's going to get done properly I suppose!
PostPosted: Fri Apr 13, 2012 4:21 am Up
Disconnect the battery before undoing the alternator cables.
Jensen
PostPosted: Fri Apr 13, 2012 5:56 am Up
Yeaa rather not blow something or myself up! Well the replacemt alternator is on, running okay but battery light coming on dim when car is revved? Guy says all the readings are fine but doesnt know what's causing the problem :/ have to get the multi meters on i when I finish work -.-
