Latest: tebas93089
Overall: 17179
Online Now [111]:
Visitors: 109
Bots: 2
Today: 17384
Total: 138164418
Forums › The Car › 206 Problems › Car stalls when RPM drops
Mercury
PostPosted: Sun Apr 15, 2012 2:12 am Up
So about 2 months ago my clutch died and I replaced it (with an original brand new clutch). Since then it was quite rare but sometimes, when slowing down to a full stop the engine would just stall. The car is usually so quiet I never noticed the engine was shut down till I needed to start moving again.
Now, past 2 days this has happened much much more and I was certain there was something wrong with the clutch so I tested it and it seems it's not. I put the car in neutral and it still happened. My RPM just drops very low and eventually the engine stalls.
What I know : This happens when I let the RPMs drop from >2500 RPM to idle. If I'm under 2500RPM the engine will hold and it will not stall (though the RPM might drop all the way to 300, then manage to climb back up.)
I tried quickly going to ~3000 RPM and then letting it go in neutral and this still happens so it's not the clutch.
When I leave the engine idling I don't see too many fluctuations in the RPM, usually sits very steady at 900RPM and maybe has a bit of play between 850-950 but nothing more.
Anyone have any ideas what this might be? I suspected the stepper motor but as the engine idles very steady I'm not sure that's the cause any more...
2005 206 XSi
PostPosted: Sun Apr 15, 2012 12:55 pm Up
Get it plugged into a code reader and see if there are any recorded faults.
PS: Knowing what model, engine type (diesel or petrol) and engine capacity would help others to offer advice but start with fault codes.
Mercury
PostPosted: Mon Apr 16, 2012 12:34 am Up
Well it's a 2005 206 XSi... I thought that narrows it down but I guess not in the UK? it's got a 110HP 1.6L petrol engine and that's pretty much the only engine we have here for the 206 XSi....
As for fault codes I'll have to stop by a shop and pay em to plug it in, I'll do that today or maybe tomorrow. As it stands right now the problem has gone to being pretty rare again, in a 20 min drive today it hasn't happened once and yesterday it happened 5 times on the drive to work, and 1 time on the way back...
Maybe it'll fix it self! Smile
2005 206 XSi
Tann206
PostPosted: Thu Apr 19, 2012 3:19 pm Up
try taking the idle control valve out and giving it a quick clean. i had similar problem, every time car revs lowered it used to cut out even sometimes when putting my clutch down coming up to a roundabout or something it would cut out then bump start back up.
A clean with lotoxane solvent cleaner did the trick for me no harm in trying!
Hope this helps
o
PostPosted: Sat Apr 21, 2012 1:56 pm Up
Sorry, missed your signature!!
