Latest: Stu-mill
Overall: 17131
Online Now [551]:
Visitors: 550
Today: 39187
Total: 104724789
Forums › The Car › 206 Problems › dashboard/airbag help
anton1989
PostPosted: Sun Apr 15, 2012 12:55 pm Up
Trade Rating: +16
just swapped my dashboard (5 hours later), its from a 5 door and my car is 3 door the one i fitted don't seem to have a airbag on the passengers side? now my air bag light is flashing which means it will fail an m.o.t what can i do, apart from put my old dash back in?
PostPosted: Sun Apr 15, 2012 1:05 pm Up
The airbag area should just pop/cut out and you can fit the airbag
anton1989
PostPosted: Sun Apr 15, 2012 1:11 pm Up
Trade Rating: +16
cheers, ill be ok till the m.o.t though wont i?
how come the 5 door does not have them?
PostPosted: Sun Apr 15, 2012 1:13 pm Up
None of the airbags will work nor seat pretensioners.
5 doors do have them, the dash will have either come off a poverty spec or a very early model
iainlovatt
PostPosted: Sun Apr 15, 2012 1:16 pm Up
I'm sure the light can be turned off by a computer, just get the car plugged into peugeot planet or similar job done,
(My Garage)
anton1989
Trade Rating: +16
so if i don't fix this asap my steering wheel airbag wont work?
PostPosted: Sun Apr 15, 2012 1:17 pm Up
Nope.
Quick fix would be to fit a resistor on the pass airbag.
@iainlovatt - no it can't as it's a perm fault
PostPosted: Sun Apr 15, 2012 1:18 pm Up
Only way to do it, would be to disable the airbag all together via changing the setting in the ECU
PostPosted: Sun Apr 15, 2012 1:22 pm Up
There is about 4 T20's holding the air bag blank in place
Easy swap
anton1989
PostPosted: Sun Apr 15, 2012 1:33 pm Up
Trade Rating: +16
Easy swap
i went to do that but my old dash is grey and the new one black, no worries ill go get a black 1 airbag 1st thing.
anton1989
PostPosted: Sun Apr 15, 2012 1:35 pm Up
Trade Rating: +16
Nope.
cheers for the help, was going to leave it but didn't know about it messing with my main airbag
anton1989
PostPosted: Sun Apr 15, 2012 1:52 pm Up
Trade Rating: +16
Nope.
1 more question will this affect my steering wheel airbag? sorry no good with this stuff
PostPosted: Sun Apr 15, 2012 1:58 pm Up
I have a black airbag if you're non-plexed?
If you fit the correct resistor then the Airbag ECU will think there is a airbag fitted, thus re-arming the SRS system
anton1989
PostPosted: Sun Apr 15, 2012 2:03 pm Up
Trade Rating: +16
what would you say i should do? yes my car is pre plexed, how much are you asking?
PostPosted: Sun Apr 15, 2012 2:06 pm Up
I'd personally fit the airbag.
Depends what equipment you have to your avail. Like I could just go out and turn the airbag off and it would take 5 minutes, or go and fit a resistor and diode as I have a stock pile of them. But it's if you can do it?
You can have it for £15 delivered.
