Online Now [1050]:
Visitors: 1049
Today: 12880
Total: 149092703
Forums › The Car › 206 Problems › throttle body conversion to cable
vitara4x4
PostPosted: Sun Apr 15, 2012 1:06 pm Up
Hi All,
on friday my aux belt decided to strip and got caught in the bottom pulley, wheel which in turn stopped the cambelt and knackerd the valves.
I got on the phone pronto and bought a 2005 206gti engine to replace mine.
the only problem i have is it is a fly by wire type.
Question:will i be able to put my throttle onto the new unit, and have it running with a cable?
i figure the engines are the same just that it has a senor.si this correct or am i barking up the wrong tree?
any help would be appreciated.
thanks Question
206CC SLAMMED TO THE GROUND
PostPosted: Sun Apr 15, 2012 1:14 pm Up
What year is your 206? Is it multiplexed?
gazza82
PostPosted: Sun Apr 15, 2012 1:26 pm Up
Take all your ancillaries off your old engine and fit to the new ... intake, exhaust, sensors ... the engine will be the same underneath the covers, etc.
PostPosted: Sun Apr 15, 2012 3:37 pm Up
All engines are the same, as above just fit the old bit to the new block and head.
vitara4x4
PostPosted: Mon Apr 16, 2012 1:35 pm Up
many thanks guys
my old engine is a gti non multiplex
the new one will arrive tomorrow
it's not been bad to take it apart but no doubt I will have left over nuts and bolts.
I get to try out my new engine hoist aswell.
thanks again Laughing
PostPosted: Mon Apr 16, 2012 4:23 pm Up
Make sure you change over all the electrical bits, basically just use the bare bones of the new engine, from the sump to the rocker cover, everything else use from your old engine.
PostPosted: Tue Apr 17, 2012 6:46 am Up
As above and I certainly wouldn't change to cable anyway.
PostPosted: Tue Apr 17, 2012 7:05 am Up
In this case he will have to. His old engine was cabe so his ecu will not be set up for an electronic throttle.
PostPosted: Tue Apr 17, 2012 7:46 am Up
OK, got it.
I thought he previously had electric setup and wanted to change to cable.
I like electric TB though much more.
PostPosted: Tue Apr 17, 2012 8:25 am Up
The engine he's bought uses comes with an electronic throttle.
Do you really? I honestly prefer cable.
PostPosted: Tue Apr 17, 2012 2:50 pm Up
Yep.
Much prefer electric.
We have two near identical 206 1.4i, one cable the other electric.
Most people say cable has instant responce etc but honestly there is no delay
by the time you put your foot down and the servo moving the throttle pane.
However, the ECU does have a way to open the throttle more (or less) depending
on driving situation with an electric TB. Economy is much better and I seem to get
more responsiveness from the car. And I love how light and quick the pedal is.
I think that's probably why most/all new vehicles use electric since it's not really cheaper
to implement, and Euro standards are getting quite strict for emmisions/consumption too.
PostPosted: Tue Apr 17, 2012 3:35 pm Up
Each to there own opinion I geuss.
I drove a 180 which uses an electronic throttle and thought it was a pathetic repsone to the cable in my GTi 138.
