Posted: Thu Apr 19, 2012 9:34 am |
GTI abs as standard
i have trolled through forums and couldnt find anything about bleeding brakes with ABS. -my apaologies if i have missed it.
i will have to fit new pads/discs soon, also my friend is in need of some new pads.
so, i have ezebleed kit, which is pretty straight forward on normal cars (no abs), but, am i right in thinking that when i push the caliper piston in: that i should open the bleed nipple so not to upset the ABS?
then ofc just bleed as normal when all the pads are fitted.
Or is there another way that i have missed?
kind regards
Posted: Thu Apr 19, 2012 9:54 am |
just bleed the brakes as normal mate, i done mine last week i have abs and i have drums on the back, just done as normal with no problems at all, and i used a coke bottle with a hose on it hahaha
Posted: Thu Apr 19, 2012 10:43 am |
If the car has ABS you should open the bleed screw before pushing the piston back in.
Posted: Thu Apr 19, 2012 10:54 am |
i will be doing this soon also and last time i did it the usual way with a coke bottle
i have never cracked the nippe prior to fitting pads etc would this have andy negative effect to the car as i have changed pads 2times and when i got my calipers fitted it was just bled up
i wil be getting mine pressure bled once i have fitted braided hoses
Posted: Thu Apr 19, 2012 10:59 am |
usher wrote: |
i wil be getting mine pressure bled once i have fitted braided hoses |
Your in for a disapointment, braided hoses are for LOOKS only on a 206.
Posted: Thu Apr 19, 2012 11:38 am |
Edward wrote: |
If the car has ABS you should open the bleed screw before pushing the piston back in. |
thanks thats what i thought
when it stops raining i'll do a photo shot of it all and put it on
Posted: Thu Apr 19, 2012 12:27 pm |
MrBSI wrote: |
usher wrote: |
Your in for a disapointment, braided hoses are for LOOKS only on a 206. |
when on the track im sure they will be better than standard as i cooked my brakes in 2 laps last year massive fade as my pedal hit the floor
ill do all i can to improve that
Posted: Thu Apr 19, 2012 1:50 pm |
They'll still fade the same as before with braided hoses fitted. Pedal will drop further still.
Posted: Thu Apr 19, 2012 2:31 pm |
that's pedal fade, you boiled your brake fluid.
even fresh stock fluid shouldn't be that bad.
Posted: Thu Apr 19, 2012 2:56 pm |
that was 5.1 but was on std discs and pads with the brembo 4pots
Posted: Thu Apr 19, 2012 3:30 pm |
which track are you doing?
