Online Now [108]:
Visitors: 107
Today: 11220
Total: 138690524
Forums › The Car › 206 Problems › fuse 15 blown in fuse box under the bonnet
nelson
PostPosted: Thu Apr 19, 2012 1:18 pm Up
Trade Rating: -1
Hi all,
I really need very fast help on this. I have one week to register my car in england and she or he decided to give lots of problems now.
Had to change the starter motor, the old one failed. Accidentally I left the wire from the battery hanging around (it was dark and working in the street). I was planning to go to work next day without starter motor (didn't had the new one yet).
So when I start the car (by pushing it) it started with lots of lights in the dashboard and noises until it stopped completely. That hanging wire from the battery was touching someplace (maybe gear box metal).
That fuse blew but it is in parallell with the hanging wire, so not sure why it blew. Today assembled the new starter motor and fit a new fuse. It worked for 2 or 3 seconds and then stopped with the same fuse blown.
The fuse is the number 15 (peugeot 1.4HDi) in the box under the bonnet. It controls the following:
- butterfly box heater
- Diesel injection pump
- Oxigen sensor
- Motor calculator
- Air mass sensor
- Motor control electrovalve
- Diesel heater
- Injectors
Do you have any ideas?
Thank you.
206 1.4Hdi =~91bhp
Upgrades: FMIC, decat, Eibach sport springs, Bilstein dampers, 21mm torsion bars, 22mm ARB, Sachs Performance uprated clutch, chiptuning
PostPosted: Thu Apr 19, 2012 1:34 pm Up
Did it blow when you started the car, or when you put the ignition on?
nelson
PostPosted: Thu Apr 19, 2012 1:37 pm Up
Trade Rating: -1
I guess it blew after I started the car (2 or 3 seconds after) which was when the engine stopped.
206 1.4Hdi =~91bhp
nelson
PostPosted: Thu Apr 19, 2012 1:51 pm Up
Trade Rating: -1
I correct what I've just said. The fuse blew even before turning the engine on.
206 1.4Hdi =~91bhp
PostPosted: Thu Apr 19, 2012 2:02 pm Up
Are you an idiot?
As im not quite sure what when through your mind that thought yeh, dam thats a good idea
PostPosted: Thu Apr 19, 2012 2:26 pm Up
Well Im guessing the postive from your battery has gone directly to anything the positve wire touched. Basically something will have got fried. Maybe a scan will show your problems.
nelson
PostPosted: Thu Apr 19, 2012 2:30 pm Up
Trade Rating: -1
Thanks Steve for trying to help. I guess there isn't much you can help really. I'll try the scan. Thanks.
206 1.4Hdi =~91bhp
parkesie
PostPosted: Thu Apr 19, 2012 3:33 pm Up
Woops good luck with getting it working again id expect all manor of stuff to be fried. Sensors ecu's the lot
Signature p**s
nelson
PostPosted: Thu Apr 19, 2012 3:42 pm Up
Trade Rating: -1
ECU responds ok to the scanner. I'll have better look this weekend and hope for the best.
206 1.4Hdi =~91bhp
nelson
PostPosted: Fri Apr 20, 2012 12:57 pm Up
Trade Rating: -1
Just for the ones interested. The car is fixed now... well, it's not fixed but it moves. The diesel heater was shorting, so now it is disconnected and it works fine.
Thank you to all that tried to help me.
206 1.4Hdi =~91bhp
parkesie
PostPosted: Mon Apr 23, 2012 2:35 pm Up
Thats a lucly escape glad it wasnt anything major.
Signature p**s
