Latest: lio94
Overall: 17181
Online Now [402]:
Visitors: 401
Today: 85999
Total: 142036457
Forums › The Car › 206 Problems › No Battery Charge and Funny Engine Characteristics Help?!!
arronmee1990
PostPosted: Fri Apr 20, 2012 10:07 am Up
On the way to work this morning my MFD flagged up saying "Battery Charge Fault". I wasn't far from work so thought I'd carry on and sort it out but then the engine wouldn't rev and I couldn't pull away from the traffic lights.
It now won't start and I've just been towed home. There is no charge on the battery, we did get the engine started once but it didn't sound very healthy and wouldn't rev up even with my foot flat.
I am initially thinking it's the alternator gone and all these other problems are just due to the battery being flat. I've had all the "Airbag fault" and "ABS fault" and "Braking fault" come up on the display.
Any ideas before I go out and buy an alternator?
Thanks in advance
My Project Thread
Ash
PostPosted: Fri Apr 20, 2012 10:31 am Up
Well the battery will be f****d now too so go and buy a good battery charger and leave it on a slow charge.
arronmee1990
PostPosted: Fri Apr 20, 2012 10:49 am Up
Yeh it will be on charge overnight but do you think it definitely is a new alternator job?
My Project Thread
Ash
PostPosted: Fri Apr 20, 2012 11:27 am Up
Put a charged battery on it. Then check the voltage across the alternator and see if its charging or not.
Jensen
PostPosted: Fri Apr 20, 2012 12:46 pm Up
Might have an alternator spare mate if you need one Smile
PostPosted: Fri Apr 20, 2012 1:58 pm Up
you have a faulty alten.,but you have to make sure it's not charging well,or is't over charging,because these 2 cases cause what you said.
craigdmjv
PostPosted: Fri Apr 20, 2012 2:31 pm Up
same symptoms as when my alternator went revs dropped and that was it lol
Jensen
PostPosted: Fri Apr 20, 2012 3:19 pm Up
Yer I've just had to change mine same faults Smile ebays best bet for one mate
arronmee1990
PostPosted: Fri Apr 20, 2012 3:40 pm Up
Thanks for the replies. I'm going to get an alternator and fit it tomorrow morning. Hopefully this and a charge if the battery and I'll be on my way again
My Project Thread
