Latest: lio94
Overall: 17181
Online Now [286]:
Visitors: 286
Today: 40085
Total: 141479081
Forums › The Car › 206 Problems › airbag prob
airbag prob
BioCustoms
PostPosted: Fri Apr 20, 2012 1:14 pm Up
Iv taken the airbags out with the dash, and now its all back in the airbag light is on, I broke one of the prongs on the passengers side airbag Plug but it looks like it still makes a connection but if it is due to the plug being broken is there way of easily fixing this without replacing the airbag since its just been flocked cheers
PEOPLE ARE TOO SERIOUS
PostPosted: Fri Apr 20, 2012 1:21 pm Up
Solder
anton1989
PostPosted: Fri Apr 20, 2012 1:23 pm Up
Trade Rating: +16
that whole lead can come out from the airbag, i got one(lead) here you can have if you pay postage?
anton1989
PostPosted: Fri Apr 20, 2012 1:24 pm Up
Trade Rating: +16
well it looks like it comes out i'll double check
BioCustoms
PostPosted: Fri Apr 20, 2012 1:45 pm Up
Top lad nice one ..... Saying that can't remember which side is broken I hope it is just the plug because the flocker dropped the Bloody thing of all parts to drop what a fool...
anton1989
PostPosted: Fri Apr 20, 2012 2:15 pm Up
Trade Rating: +16
looks like it comes out but its not? does anyone know how to take it out?
PostPosted: Fri Apr 20, 2012 2:18 pm Up
have you turned the ignition on while the airbags were off??
If you did,then the ECU had a fault stored,and you need to erase it so the light goes off.
anton1989
PostPosted: Fri Apr 20, 2012 2:26 pm Up
Trade Rating: +16
i started mine with no airbag, and i drove it, then when i got a new airbag and fitted it the light went off
BioCustoms
PostPosted: Fri Apr 20, 2012 2:49 pm Up
i did start the engine with the passengers side out so that may be it i think i might have to take it some where to have a look if i cant sort it out
PostPosted: Sat Apr 21, 2012 3:40 am Up
The airbag system on the 206 does a self test when the ignition is switched on.
If there is no fault found with the system the airbag warning light / lights will go out.
Fix the fault & the light should then go out by itself.
PostPosted: Sat Apr 21, 2012 1:20 pm Up
Thank you for the info Very Happy Thumbs Up
