Posted: Fri Apr 20, 2012 1:14 pm |
Iv taken the airbags out with the dash, and now its all back in the airbag light is on, I broke one of the prongs on the passengers side airbag Plug but it looks like it still makes a connection but if it is due to the plug being broken is there way of easily fixing this without replacing the airbag since its just been flocked cheers
| PEOPLE ARE TOO SERIOUS
My car: 1.4 Lx 2002 silver. With only 25,700 miles and completely standard ...... AT THE MOMENT ANYWAYS
Prog Thread: www.206info.co.uk/Foru...42301.html | |
Posted: Fri Apr 20, 2012 1:21 pm |
Solder
Posted: Fri Apr 20, 2012 1:23 pm |
Trade Rating: +16
that whole lead can come out from the airbag, i got one(lead) here you can have if you pay postage?
Posted: Fri Apr 20, 2012 1:24 pm |
Trade Rating: +16
well it looks like it comes out i'll double check
Posted: Fri Apr 20, 2012 1:45 pm |
Top lad nice one ..... Saying that can't remember which side is broken I hope it is just the plug because the flocker dropped the Bloody thing of all parts to drop what a fool...
Posted: Fri Apr 20, 2012 2:15 pm |
Trade Rating: +16
looks like it comes out but its not? does anyone know how to take it out?
Posted: Fri Apr 20, 2012 2:18 pm |
have you turned the ignition on while the airbags were off??
If you did,then the ECU had a fault stored,and you need to erase it so the light goes off.
Posted: Fri Apr 20, 2012 2:26 pm |
Trade Rating: +16
| Timon2210 wrote: |
If you did,then the ECU had a fault stored,and you need to erase it so the light goes off. |
i started mine with no airbag, and i drove it, then when i got a new airbag and fitted it the light went off
Posted: Fri Apr 20, 2012 2:49 pm |
i did start the engine with the passengers side out so that may be it i think i might have to take it some where to have a look if i cant sort it out
Posted: Sat Apr 21, 2012 3:40 am |
The airbag system on the 206 does a self test when the ignition is switched on.
If there is no fault found with the system the airbag warning light / lights will go out.
Fix the fault & the light should then go out by itself.
Posted: Sat Apr 21, 2012 1:20 pm |
| MrBSI wrote: |
Fix the fault & the light should then go out by itself. |
Thank you for the info
