Posted: Fri Apr 20, 2012 2:42 pm |
Sounds to me like a tracking problem. Unbalanced wheels would only cause horrible vibrations through the steering wheel and cause numbness in the hands and fingers.(I have felt this before)
Posted: Fri Apr 20, 2012 3:57 pm |
It could all be down to having 2nd hand tyres put on your car.
In future save up & get decent tyres.
Posted: Fri Apr 20, 2012 5:35 pm |
anton1989 wrote: |
Seabook wrote: |
they will, but who knows how much are they going to charge you.
can't believe people don't even have basic cover |
its only £5 a month if that.
but then again look how much it is to get insured these day, im getting quotes of £3000 on a 1.1! |
basic is 20 pound a year....
Posted: Fri Apr 20, 2012 5:36 pm |
DeadEyePaul wrote: |
Sounds to me like a tracking problem. Unbalanced wheels would only cause horrible vibrations through the steering wheel and cause numbness in the hands and fingers.(I have felt this before) |
if you have 2 different front tyre the traction will be different
Posted: Sat Apr 21, 2012 4:24 am |
Trade Rating: +59
Swap the tyres around
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Sat Apr 21, 2012 6:01 am |
The drive shaft is broken
How much will i be looking at to get it fixed
Posted: Sat Apr 21, 2012 7:27 am |
Trade Rating: +36
Pm Cartoonhead for a quote.
Two things I would advise is never use part worn tyres as you never know the history of them and if your going to use motorway's get breakdown cover, The company's the highways agency use charge over £100+ just to remove your car from the motorway.
Posted: Sun Apr 22, 2012 7:06 am |
just had the tracking done and had the driver shaft changed on driver side. now the car does not turn when braking but the steering is still a bit loose sometimes the wheel moves left and right and it is still not straight at all times. while driving the car moves a bit left and right it self. its like sitting in a death trap.
any ideas what the problem could be? the wishbones are ok on both sides and there is no play in the wheels.
tire pressure for all 4 tires is at 32psi. wheels have been balanced. tires have been changed.
Posted: Wed Apr 25, 2012 3:15 pm |
PROBLEM SORTED.
the wishbone on the passenger side had gone so had that replaced and had the tracking done again. working fine now.
thanks
Posted: Wed Apr 25, 2012 3:16 pm |
Good to hear - Nice that its all been sorted and safe again.
