Online Now [41]:
Visitors: 40
Today: 67716
Total: 117181098
Forums › The Car › 206 Problems › clutch cable or gearbox
Go to page Previous  1, 2
Tam80
PostPosted: Mon Apr 23, 2012 6:55 am Up
i am thinking its enough to draw in air but not let any fluid out...ie fluids thicker...its been caused by my f****** induction cone rubbing against it :@
as my clutch still works but is notchy and bite is mega high...no warnings or nothing..just happened suddenly
206/GT/GTI
Tam80
PostPosted: Mon Apr 23, 2012 6:56 am Up
yeah it is a hole..thats the braid inside showing
206/GT/GTI
PostPosted: Mon Apr 23, 2012 6:57 am Up
Nice.
Tam80
PostPosted: Mon Apr 23, 2012 11:42 am Up
Bump
206/GT/GTI
gazza82
PostPosted: Mon Apr 23, 2012 12:56 pm Up
I would have thought if the bite point is high, it isn't the clutch fluid .. that would mean the bite point was nearer the floor. You could try and bleed the clutch but I think it's going to be OK.
If that wear in the hose was letting air in, it would let fluid out. It might be thicker but it's under a fair amount of pressure when you push the pedal down. But the hose is multi-layered. There's another hose under the braiding, which is there for strength, then another over that (which is worn through). Check all the pipe from the master cylinder to the slave .. our 1.4 hose went were it joins the metal pipe but under the battery tray so it was hard to see ... but the pedal just went to the floor. Doddle to replace though as they clip in ... then it needs bleeding.
I can't be 100% but I think your clutch is worn and the self-adjustment on the hydraulics has been taken up. If it was ragged, the driver has probably slipped and burnt the clutch a few times ... Rolling Eyes
Tam80
PostPosted: Tue Apr 24, 2012 4:56 am Up
oh oh dont like the sound of that...i aint losing fluid nowhere but will check all the pipes again then bleed it and hope it makes some difference...hope it at least gets rid of the notchiness in the pedal
is it possible for a slave to be f***** but not leak ?
will get good lady to press pedal and i will see whats happening at slave end...so if slave aint pressing right that means that my problem is slave back...and if it is pressing right in then my problem is in the box somewheres ???
this sound bout right ???
206/GT/GTI
Tam80
PostPosted: Wed Apr 25, 2012 12:56 am Up
right here goes lol...dont know techical name for it...the arm that comes out gearbox that slave attaches to...is shivvvering lol...its shaking and thats what i am feeling through clutch pedal....bled clutch slave yesterday..think its made a slight difference if any
anybody any ideas whats making it shake lol
206/GT/GTI
gazza82
PostPosted: Thu Apr 26, 2012 1:59 pm Up
Without being able to see or feel, I think it's probably the clutch release bearing or the clutch itself ...
Probably not the news you wanted ... Sad
Page 2 of 2
