Online Now [602]:
Visitors: 601
Today: 35635
Total: 146738345
Forums › The Car › 206 Problems › Door Stuck
Door Stuck
alborough1974
PostPosted: Thu Apr 26, 2012 12:06 pm Up
Hi all
Having just brought a 2002 206 SW im now having my first problem with it.
The NSF door is not responding to either the inside or outside handles even though the door is unlocked.
I'm guessing that i'm gonna have to release the door card so is this going to be easy to do with the door stuck closed. Also is this going to be easy enough to sort once the card is off or is it likely to be more complex. Any help / advice will be apreciated
2002 Peugeot 206 1.4 XT SW
alborough1974
PostPosted: Thu Apr 26, 2012 12:07 pm Up
It's the NSR door thats faulty not the NSF
PostPosted: Thu Apr 26, 2012 1:28 pm Up
once you pop the door card and remove the insulator sheet you will see how the lock mechanism work and you can work from there
-Dave-
PostPosted: Thu Apr 26, 2012 1:40 pm Up
Trade Rating: +36
Can you take the door card off while it is closed. I though there was a torx screw on the side?
Ex 206 Owner.
gaffa786
PostPosted: Thu Apr 26, 2012 2:02 pm Up
What He Said
DeadEyePaul
PostPosted: Thu Apr 26, 2012 2:09 pm Up
Yep a new door card will be needed unless you can carefully break it around that screw
PostPosted: Thu Apr 26, 2012 2:45 pm Up
Can you not 'bend' the whole card slightly and stick your hand in there to poke around
without breaking the whole card and needing a new one?
PostPosted: Thu Apr 26, 2012 2:58 pm Up
it's plastic, it will bend quite a lot without breaking Laughing
alborough1974
PostPosted: Mon May 21, 2012 12:13 pm Up
Well i've finally got this problem sorted. It was a broken clip that secures the lock rod from the exterior to the lock unit which allowed the rod to fall out. New clip is now on order so will fit as soon as it arrives also child lock was on hence the reason why it wouldn't open from the inside.
The door cards on SW dont have the torx screw on the side so that made things easier.
All in all it was a good result
