Latest: Beduff1977
Overall: 17134
Online Now [456]:
Visitors: 455
Today: 105502
Total: 109276171
Forums › The Car › 206 Problems › New icv fitted - still having issues update 29/04/12
PostPosted: Mon Apr 09, 2012 6:07 am Up
As i discussed in my earlier thread
www.206info.co.uk/Foru...43787.html
2 days after fitting, set off from my house when engine light came on and there was a loss of acceleration and revs dropped right down but car didn't stall and went back to normal.
A week later (today) and i pick the gf up to grab a maccy d's and traffic was heavy so engine was quite hot by the time we parked up, was parked up for about 20mins, started the car with no problems, drove for 10metres before having to stop when the engine light came on, the revs dropped right down and the engine cut out, it did this everytime i came to a halt but also while driving in 4th there was a slight jolt of the car when the engine light came on.
got home and parked up while the revs dropped right down but did not stall, when the car was stationary i left the engine running and it was idling fine.
Any ideas which does not involve the icv as this was replaced, i'm thinking maybe the coilpack, spark plugs, maybe even the engine oil could be the reason
Any help would be appreciated as it is making me want to get rid of the 206 Crying or Very sad
Lecktorious
PostPosted: Mon Apr 09, 2012 6:11 am Up
Trade Rating: +59
Coilpack.
'98 Nile Blue 306 GTi 6
oldskoolz
PostPosted: Mon Apr 09, 2012 6:14 am Up
try the MAP sensor
Black 206 Gti. Soon to be 2.2
cartoonhead
PostPosted: Mon Apr 09, 2012 6:19 am Up
Lecktorious wrote:
Coilpack.
What He Said
PostPosted: Mon Apr 09, 2012 7:01 am Up
Fault code read ?
PostPosted: Mon Apr 09, 2012 7:27 am Up
Steve206 wrote:
Fault code read ?
That should be the first port of call
PostPosted: Sun Apr 29, 2012 4:31 am Up
had the car put on a diagnostic machine and no fault was found. It happens when the engine is hot, the engine warning light will come on and as soon as i stop, the engine cuts out. The only time it doesn't misbehave is when the engine is cold and i drive from the gf's to my house or to and from work each day
PostPosted: Sun Apr 29, 2012 4:39 am Up
Was it Peugeot Planet? You definetly have a fault, maybe it occurs before a fault is logged? Cant you do live logging which might pick it up if it onnly happens when warmed up?
PostPosted: Sun Apr 29, 2012 4:40 am Up
did you ever check the plug?
PostPosted: Sun Apr 29, 2012 4:52 am Up
no it was my local garage i use who tested, when they tested it the engine light had just come on only minutes before but still nothing was found, car will be going in garage hopefully tuesday to get sorted
sulli
PostPosted: Sun Apr 29, 2012 5:14 am Up
Strange how it's not logging a fault if it was doing it all the time I'd say coil pack but only doing it when it's getting warm is weird.
206 VAN SILVER!
www.Sheffield-WebDesigns.co.uk - discount for 206info members!!
www.HealthyCigs.co.uk - discount for 206info members!! quote - 206info
PostPosted: Sun Apr 29, 2012 5:45 am Up
it used to do it when i first got the pug, went to peugeot and even they couldn't find a fault but changed the coilpack and everything was fine afterwards until a few weeks ago
craigdmjv
PostPosted: Sun Apr 29, 2012 6:06 am Up
have you got any looses connection in wiring maybe earths
PostPosted: Sun Apr 29, 2012 6:11 am Up
not that i'm aware of mate
craigdmjv
PostPosted: Sun Apr 29, 2012 6:54 am Up
ohhh im unsure aha
