Latest: S2cgm
Overall: 17178
Online Now [124]:
Visitors: 122
Bots: 2
Today: 62056
Total: 136761088
Forums › The Car › 206 Problems › 'Idle' Problem
'Idle' Problem
Shodoku
PostPosted: Tue Apr 24, 2012 5:39 am Up
When my car idles, it makes a 'churning' sort of sound and the rev needle jumps very slightly above 900rpm in time to it. This has only been an issue since the new manifold/decat.
The first thing that springs to mind is 'idle control valve' but I wanted to check with you guys to see what you think?
Thanks in advance.
Shodoku
PostPosted: Mon Apr 30, 2012 6:20 am Up
Anyone?
PostPosted: Mon Apr 30, 2012 7:02 am Up
A few details about your car would be beneficial, but if it's only happened since the new manifold/decat, I would start there.
Shodoku
PostPosted: Tue May 08, 2012 5:51 am Up
1.1 Y reg, 2001.
I didn't really want to start taking everything apart unless I was certain it was causing the problem.
PostPosted: Tue May 08, 2012 8:07 am Up
What did you do about the post-cat (second) sensor?
Shodoku
PostPosted: Mon May 14, 2012 3:38 am Up
It's blanked off using a blanking sleeve.
