Online Now [194]:
Visitors: 193
Today: 70208
Total: 142113639
Forums › The Car › 206 Problems › 206 Vs Puddle
206 Vs Puddle
CPB46
PostPosted: Mon Apr 30, 2012 4:27 am Up
Well... put simply, was out in my 2000reg 2.0HDI yesterday and went through what i thought was jus a bit of surface water....turned out to be a bit deeper than i first thought!
Engine didnt bog down or have any problems, not caused any knocks or rattles or anything. Shortly after my engine management light came on and ive lost boost. (rest of the journey was gutless til 2250rpm then a ton of boost, today, no boost at all)
Can hear the turbo spinning up, but runs like its on limp home mode. Took the airfilter out and it was pretty wet, dried the airbox and took it for a spin to see if the wet filter was restricting the flow, no change in performance.
What sorta things should i be looking at, is there a chance it could just dry out?
Cheers, Craig
rick-gti
PostPosted: Mon Apr 30, 2012 4:40 am Up
Is your oil ok? Check it for signs of water. Look for a mayo colour on the oil cap. Water can get sucked up the air intake.
clio 197sport owner
CPB46
PostPosted: Mon Apr 30, 2012 7:32 am Up
Got no signs of water in the oil.
PostPosted: Mon Apr 30, 2012 7:39 am Up
You might get away with drying it out. If your airbox got soaked, there is a good chance that some of the electrics did too.
If the EML is on, get the codes read and see what it says. Might be a damaged sensor or even just a connector that has become dislodged from the water hitting it.
PostPosted: Mon Apr 30, 2012 11:01 am Up
most likely you need to clean the MAF sensor
PostPosted: Mon Apr 30, 2012 12:01 pm Up
Already has, but with water Rolling On The Floor Laughing
PostPosted: Mon Apr 30, 2012 1:11 pm Up
LOL...you can be so funny sometimes Mr. :D,get it scanned,and change the airfilter don't wait for things to dry,you are so lucky that the water have not been sucked through air to your engine,or your engine would say bye bye Sad
Rob2859
PostPosted: Mon Apr 30, 2012 4:23 pm Up
Strike number 3 for water induction in the past 7 days...
CPB46
PostPosted: Tue May 01, 2012 6:50 am Up
Its drying out at the mo, as i yesterday found quite a bad power steering fluid leak , ordering the pipe today so once thats sorted gonna take it for diagnostics. (assuming it hasnt simply dried)
Dont feel quite so silly being the 3rd person to do it lol.
Whilst i was out tinkering yesterday, fitted my new wheels, so as soon as shes on on the road again will get some pics up Smile
rick-gti
PostPosted: Tue May 01, 2012 6:53 am Up
Hope you get it sorted. Stay away from big puddles Wink
clio 197sport owner
CPB46
PostPosted: Fri May 11, 2012 5:35 pm Up
Just a quick update..
Managed to repair the low pressure power steering pipe. Had been rubbing on the High pressure pipe running parallel and worn through.
Took the car for diagnostics, had a code for MAF sensor. Taken it off, cleaned it up...and she runs like a dream again! Very Happy
Hoping for a sunny weekend to get the service done and give the car a good scrub up! (with as little water as possible! Lol )
PostPosted: Sat May 12, 2012 2:20 am Up
Razz Thumb Up
CPB46
PostPosted: Tue May 15, 2012 8:27 am Up
Good shout mate Smile
Fully serviced n cleaned, got a few pics over the weekend, will upload soon!
Cheers for the help! Muchly appreciated!
Craig
