Latest: tebas93089
Overall: 17179
Online Now [252]:
Visitors: 251
Today: 31160
Total: 138132978
Forums › The Car › Request a how-to › Spray centre console
Forum IndexRequest a how-to
btownsend06808
PostPosted: Mon Apr 30, 2012 5:00 pm Reply with quote Up
Best way to do this any tips ??
QuArTz
PostPosted: Mon Apr 30, 2012 5:16 pm Reply with quote Up
Trade Rating: +16
In exactly the same way as colour coding rub strips.
Use plastic primer and away you go...
btownsend06808
PostPosted: Mon Apr 30, 2012 5:18 pm Reply with quote Up
Cool cheers so just primer paint then lacquer ?
Lowercase
PostPosted: Tue May 01, 2012 12:09 am Reply with quote Up
and a sod load of rubbing down. and flatting back.
Jensen
PostPosted: Tue May 01, 2012 12:41 am Reply with quote Up
I sprayed mine the other week Smile really simple to do, and got a great finish
btownsend06808
PostPosted: Tue May 01, 2012 4:43 pm Reply with quote Up
How did undo yours ?
hayes_ctfc
PostPosted: Mon Aug 13, 2012 4:44 am Reply with quote Up
Is it just a case of prying it off with a flathead to remove it?
OLD: Peugeot 206 2.0 GTi 138
NEW: Seat Leon FR TDi 170
DeadEyePaul
PostPosted: Mon Aug 13, 2012 4:57 am Reply with quote Up
Almost Haynes! There's 2 torx t20's under the clock surround.
Clock
Surround is removed by pushing it towards the windscreen. Then there is those two bolts I mentioned earlier.
Undo those and give it a tug towards you
devildriverxii
PostPosted: Tue Sep 18, 2012 3:41 pm Reply with quote Up
Go easy on the lacquer.
it's where I always mess up, runs like Usain Bolt.
2002 1.6 5dr Black Edition.
thatplace
PostPosted: Tue Sep 18, 2012 4:01 pm Reply with quote Up
putting too much on at a time then, light/thin coats
  Quick Reply
Username:
Message:
Quote the last message
