Online Now [705]:
Visitors: 704
Today: 1665
Total: 145900650
Forums › The Car › Solved 206 Problems › help wanted
help wanted
Forum Index › Solved 206 Problems
gaznandrea
PostPosted: Wed May 02, 2012 10:12 am Up
when it rains and my car is parked both my front seatbelts when you npull them out are wet has anybody any ideas cheers gaz
black peugeot 206 gti 180 lowered all round morrette headlights smoked tail lights full cobra exhaust
dj71
PostPosted: Wed May 02, 2012 10:23 am Up
you could try using a watering can, pour a little around the edge of the doors (when they are shut that is lol) then you might find a bad door rubber seal, and the same with the rear quarter glass if its a 3 door, mine leaks there a little in the rain
dj71
PostPosted: Wed May 02, 2012 10:24 am Up
Door seals perished? Drain holes blocked in the seals?
gaznandrea
PostPosted: Wed May 02, 2012 10:43 am Up
ill try all othese ideas cheers folks
