Posted: Thu May 03, 2012 1:43 am |
Hi was just wondering if it was physically possible to put a 2.0 gti 136 engine in a 1.1? Thanks
Posted: Thu May 03, 2012 1:59 am |
Anything is possible if you have the tools, knowledge and inclination, but I don't think it is as straight forward as swapping lumps over. You would probably have to swap looms, ECU, BSI, It would be advisable to upgrade the suspension and the brakes.
IMO it wouldn't really be worth the hassle and would be easier looking for a 138 to work on as a project.
Posted: Thu May 03, 2012 2:03 am |
It can be done but would be cheaper to just buy a gti. If you do it might be worth just buying a cheap gti for the parts (i break them and pick them up for lees than £400) as you will need: engine and box, suspension, brakes, subframe, hydrolic clutch ecu, wiring loom, bsi cat and exhaust system. might have missed some parts, but you can see its a big job.
Posted: Thu May 03, 2012 4:06 am |
Have a search this question has been asked sooooo many times
Posted: Thu May 03, 2012 7:24 am |
Do it i you think you can, but it depends if you tell the dvla/insurence then it just wouldnt be worth your while.
if you think you can get away with it then bonus
Posted: Thu May 03, 2012 7:43 am |
sulli wrote: |
Hi was just wondering if it was physically possible to put a 2.0 gti 136 engine in a 1.1? Thanks |
Yes.
Posted: Thu May 03, 2012 9:00 am |
rick-gti wrote: |
It can be done but would be cheaper to just buy a gti |
Fitting a GTI lump in to a 1.1 206 is a pointless money wasting conversion these days.
206 GTI's are so cheap to buy these days if you really want one.
