Latest: Kifi69
Overall: 17183
Online Now [433]:
Visitors: 432
Today: 59776
Total: 144687806
Forums › The Car › 206 Problems › Running Problems
Running Problems
karlosthejackal
PostPosted: Thu May 03, 2012 12:26 pm Up
Hi everyone
I have a 206 W Reg. 1.4 Auto misfiring on 2 cylinders.
Mechanic has plugged the laptop in and it isn't showing a fault code.
Two of the plugs were black so the plugs and the coil pack were changed but still misfiring.
The mechanic seems to think its either an electrical problem or the ECU is kaput!
Anyone any ideas?
Could it be a relay?
\'It took a tattoo\'d boy from Birkenhead to really really open her eyes\'
richpowell91
PostPosted: Thu May 03, 2012 12:43 pm Up
Has your mechanic tested the injectors? When mine have gone before there was a miss fire and no engine management light showed so that would be the next thing i would check.
Also if the spark plugs that were fitted were NGK get your mechanic to change them for Bosch plugs, NGK plugs can often cause misfires.
karlosthejackal
PostPosted: Thu May 03, 2012 1:02 pm Up
Thanks Rich
He did a compression test and that was fine but I'm not sure if he checked the injectors.
I will give him a call tomorrow
