Latest: lio94
Overall: 17181
Online Now [130]:
Visitors: 129
Today: 13501
Total: 141264260
Forums › The Car › 206 Problems › wishbone needs replacing?
Go to page 1, 2, 3  Next
karimali831
PostPosted: Thu May 03, 2012 7:59 am Up
After having my tyres replaced and bolted on I noticed the front wheel can tilt left and right, could it be anything else apart for the wishbone that needs replacing and is it expensive to change? Probably explains why the ESP flashes on the dash all the time when having fast starts, was hoping it was because of the no tread on my old tyres, fix 1 problem just to find the next, gutted! Mad
206 GTI 180
Big_Rich180
PostPosted: Thu May 03, 2012 8:00 am Up
Welcome to Peugeot ownership.
PostPosted: Thu May 03, 2012 8:23 am Up
Could be wheel bearing that needs changing
dj71
PostPosted: Thu May 03, 2012 9:37 am Up
i just got 2 wishbones from dcp at £34 each
dj71
PostPosted: Thu May 03, 2012 9:54 am Up
Had mine replaced under Peugeot 3 year manufactures warranty back in 2005 & there still on the car now.
Buy cheap = buy twice Wink
PostPosted: Thu May 03, 2012 10:49 am Up
buy twice is already very generous.
Adam replace the wishbone 3 or 6 times within a yr Laughing Razz
gaffa786
PostPosted: Thu May 03, 2012 1:47 pm Up
if the wishbone needs replacing you will be able to tell while driving the car. this happened to me and the car was stupidly dangerous to drive. when you break it would turn one way and when you accelerate it will turn the other way. bit scary as you don't know if your going to die while going left or right
karimali831
PostPosted: Fri May 04, 2012 12:20 pm Up
I could only tell when having a quick start, it wasn't nothing as major as yours but replaced mine today anyway and tracking done also, now has better handling and distinguish the flashing ESP Smile
206 GTI 180
SinfulDesignCom
PostPosted: Fri May 04, 2012 7:00 pm Up
It only takes a slight imperfection in the cast to weaken the structural integrity by a long way. One of these goes at speed and you are fubarred... Go for OEM or lemforder - sure they are more expensive, but at least you won't shat yourself every time you hit a pot hole...
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
kenny16m
PostPosted: Wed May 23, 2012 2:57 pm Up
Im changing these things 4/5 times a year, any idea what i can do, ive had oem parts one set lasted me 2 years now my other set, only lasted me 3 months, now just doing cheap as cant keep on with this, are there anyother things that can cause these things to go?
GT Dturbo
Team : Austin Healey Sprite
PostPosted: Wed May 23, 2012 2:59 pm Up
how low is your car?
kenny16m
PostPosted: Wed May 23, 2012 3:07 pm Up
Normal, car totally standard
GT Dturbo
PostPosted: Wed May 23, 2012 3:14 pm Up
unless you keeping hitting kerb and pothole at speed otherwise i can't see why that happen?
mine was fine for the past 4-5 yrs
SinfulDesignCom
PostPosted: Wed May 23, 2012 3:15 pm Up
Something doesn't sound right here. When you say they are not lasting - I assume you are talking about the ball joint? Surely they cannot be breaking? Otherwise it can only be the bushes and the simple answer to that is to fit poly bushes. Failing that I would check the front subframe for defects, but I really can't see that being the case unless the car has been in the mother of all prangs...
kenny16m
PostPosted: Wed May 23, 2012 3:20 pm Up
Its the ball joints at fall all the time, every one i change the actuall bushes are fine,
Its always the ball joints that start to knock,
The front sub seams to be fine, had the car 6 years, only had problems the last say 18 months
GT Dturbo
Page 1 of 3
