Latest: cogeim7
Overall: 17185
Online Now [658]:
Visitors: 657
Today: 107652
Total: 147233388
Forums › The Car › 206 Problems › 206 clutch
206 clutch
Timxs
PostPosted: Sun May 06, 2012 11:05 am Up
Hi all,
My son has a 7 year old 206 with about 55000 miles on the clock.
The clutch bite is right at the top of the pedal travel at the moment.
Is this adjustable?
Do 206 clutches usually last longer than 55000 miles?
Any help or advice would be gratefully recieved.
Many thanks.
Tim.
pug206lx
PostPosted: Sun May 06, 2012 11:12 am Up
Is it a petrol, diesel or GTI?
The petrol models have an automatic adjuster that can't be unadjusted - the cable needs to be replaced. The GTI is hydraulic and I think the diesel is too.
PostPosted: Sun May 06, 2012 11:19 am Up
Easily yes BUT it depends on the operator.
benjsy
PostPosted: Sun May 06, 2012 11:24 am Up
ive had problems with mine, when i change gear the clutch sticks at the top just as i go on the gas, but i just let the clutch go fully out before gas now and its pretty much fine
B Carlisle
snagger
PostPosted: Tue May 08, 2012 10:19 am Up
Reference the clutch travel, I have a 1.4 "X" reg petrol that bites towards the top of the pedal. I read in an earlier post that it could be time to replace the cable as it automatically adjusts in the petrol model. I just wondered i this could be confirmed please? It has done 126,00 miles and i've had it for 3 weeks Smile
Cheers
\"Snagger\"
Gti180Mac
PostPosted: Sat May 12, 2012 4:15 am Up
The biting point on my car is also very high, but no judder or slip??. Any pointers??
New Pug Fan!!!
PostPosted: Sat May 12, 2012 12:48 pm Up
I think most of them are and you get used to it after a while.
It is the case that with good use you might never have to replace the clutch/disk esp. on the
smaller engine models. The only reason I replaced mine at 90000 Km was to make it lighter
and help a sensitive left knee. It had plenty of life left in it as we expected when removed the old one.
I would say it wasn't even half-worn but the spring combs had hardened over time/use due to metal fatigue.
Anyway, Valeo OEM recommended.
