Online Now [538]:
Visitors: 537
Today: 22010
Total: 106216239
Forums › The Car › 206 Problems › HELP! fitting ball joint on a 206 gti.
rick-gti
PostPosted: Mon May 07, 2012 3:51 am Up
URGENT!
Has anyone done one before? Im having problems trying to allign the hub. Does the track rod end need to be taken off?
clio 197sport owner
PostPosted: Mon May 07, 2012 3:58 am Up
Its a total b***h! I found it easier with another pair of hands. Try to jack the hub up this will give you more room to play with. My car isnt lowered, so i also tightened up my springs with exhaust clamps. no need to remove the track rod.
PostPosted: Mon May 07, 2012 4:01 am Up
Im assuming your changing the whole wishbone?
rick-gti
PostPosted: Mon May 07, 2012 4:21 am Up
Im replacing the driveshafts. I cant seem to get the hub in line. When I jack the hub up it keeps moving off centre. Would using spring clams help?
clio 197sport owner
PostPosted: Mon May 07, 2012 4:48 am Up
Get two people so one can pressure the driveshaft in. and keep trying may take a while
I never use a jack, just pops it out of alignment, just line it up until it's nearly in then tap it with a hammer
rick-gti
PostPosted: Tue May 08, 2012 1:53 am Up
Managed to do it by using spring clamps. Compressed the spring enough for me to align the hub and ball joint. Goes in alot easier than it comes out.
clio 197sport owner
PostPosted: Tue May 08, 2012 11:15 am Up
Meant to say spring clamps, not exhaust!
PostPosted: Tue May 08, 2012 11:38 am Up
I paid a mechanic £40 to change both. Not worth the hassle.
