Latest: tbafonso
Overall: 17130
Online Now [131]:
Visitors: 130
Today: 10083
Total: 104591871
Forums › The Car › 206 Problems › DPF cleaning
DPF cleaning
Go to page Previous  1, 2
PostPosted: Tue May 08, 2012 5:40 am Up
We where talking to Turbo Technics last week & they quoted around £1100 to supply & fit a service / exchange unit.
DV6 turbo exchange isnt just bolt a new turbo on, there is a lot of other engine work that needs doing unless you want the replacement turbo to fail very quickly.
PostPosted: Tue May 08, 2012 5:45 am Up
ok i didn't realized it cost that much Laughing
i always presume is the oil feeder pipe got blocked and then boom....
PostPosted: Tue May 08, 2012 5:46 am Up
Thats still cheaper then a service / exchange unit from Peugeot / Citroen as a part only Shocked
Ghosty
PostPosted: Tue May 08, 2012 5:56 am Up
well if mine is the original, it has done 112k so is about due for renewal.
Team > Black HDi GTi Stage 1 tuned (140bhp, 235lbs/ft)
Team > Ex HDi D-Turbo owner
W.I.P. > www.206info.co.uk/Foru...rt=15.html
Lecktorious
PostPosted: Tue May 08, 2012 6:11 am Up
Trade Rating: +59
If you use the wrong grade of oil, you risk knackering the turbo. If it ain't broke, don't fix it (but on a DV6, I'd prepare for the worst Laughing )
'98 Nile Blue 306 GTi 6
darratt78
PostPosted: Tue May 08, 2012 6:41 am Up
Mine was replaced in August last year with new feed and return pipes so fingers crossed!
206 hdi GTI
PostPosted: Tue May 08, 2012 6:49 am Up
pub quiz, what oil should you use? Laughing
darratt78
PostPosted: Tue May 08, 2012 6:58 am Up
Would be very interested to know..... Will do an oil change at some point this year. No-one can agree on this forum what grade is best!
206 hdi GTI
PostPosted: Tue May 08, 2012 7:41 am Up
Laughing
you need ACEA C2 or C3 oil (low ash)
and usually they only came in 5w/30.
you are not recommanded to use oil for let say TU5 or EW10 or DW10 engine.
Ghosty
PostPosted: Tue May 08, 2012 7:48 am Up
thanks seabrook, i was thinking of an oil change come the end of the month, will have to make sure correct oil is used Very Happy
darratt78
PostPosted: Tue May 08, 2012 12:12 pm Up
Cheers seabrook, I'm guessing Mobil 1 ESP or castrol edge might be a good shout. Will be heading to Gsf or euro for that though, ain't getting mugged up in halfords!
206 hdi GTI
PostPosted: Tue May 08, 2012 1:29 pm Up
Thumb Up
ESP is fine, but castrol edge comes in different grade so you better check the label.
Page 2 of 2
