Online Now [555]:
Visitors: 554
Today: 31901
Total: 106161545
Forums › The Car › 206 Problems › Water inside car!
Water inside car!
gaffa786
PostPosted: Tue May 08, 2012 6:36 am Up
So i woke up to go uni got into my car and noticed there was a little puddle on the driver side mat. I lifted the mat and the carpet below was also wet from the rain.
Any idead as to how it could have come through and from where. All the other parts are dry, the seats are also dry. :s
PostPosted: Tue May 08, 2012 6:48 am Up
Have you had the door cards off recently?
gaffa786
PostPosted: Tue May 08, 2012 6:52 am Up
I took them off once about a month ago to upgrade my speakers but i put them back properly. It has rained alot since then but only last night it has seemed to have gone through
gaffa786
PostPosted: Wed May 09, 2012 3:33 am Up
Bump
Davies
PostPosted: Wed May 09, 2012 3:37 am Up
gaffa786 wrote:
Bump
PM me mate
Poppy, My 2.0 HDI Dream Wink
PostPosted: Wed May 09, 2012 3:48 am Up
Check the drain holes at the bottom of the door to make sure they aren't blocked. Did you reseal the plastic/foam inner liner when you replaced the door cards?
The aerial mounts on the front have a habit of leaking if they have been disturbed but that usually ends up in a puddle around the gearstick
gaffa786
PostPosted: Wed May 09, 2012 3:51 am Up
Not sure where the drain hole on the door is. And i didnt remove the foam as it did not come in the way so i left it how it was untouched. And thanks ill have a look at the aerial mount
VorTechS
PostPosted: Wed May 09, 2012 3:53 am Up
Staff - Vortechs
The drain holes are at the bottom of the door as macca said. If you open the door and look underneath it you'll see them.
If you have any discarded rubbish (speaker wire etc) it could be blocking these holes.
PostPosted: Wed May 09, 2012 3:57 am Up
Mate of mine had water in the footwells everytime it rained on an old Fiesta due to the sill drain holes being blocked.
Typical crap Ford design, they decided to make the sunroof drain tubes empty out in to the sills Rolling Eyes
He did have the complete dash & windscreen out while trying to find the leak Laughing
Wonder how many people on here actually bother to check / clear the drain holes Wink
Stuartjolly
PostPosted: Fri Jan 17, 2014 11:10 am Up
Can any one photograph these drain holes please I am sure they are not on my car, I'm having the same leaking problem!
Thanks in advance
206 1.1LX Silver 1998
RoweY
PostPosted: Fri Jan 17, 2014 11:25 am Up
Sometime it's just the door seals mate i happen on my old 1 and i changed the door seal and never leaked again Very Happy
Lecktorious
PostPosted: Fri Jan 17, 2014 11:40 am Up
Trade Rating: +59
Thanks in advance
Look at the door from the bottom. They are on the seam between the inner and outer skin.
'98 Nile Blue 306 GTi 6
PostPosted: Fri Jan 17, 2014 12:17 pm Up
You can just see one in this picture (bottom right), there is a similar one towards the front of the door too.
