Online Now [300]:
Visitors: 299
Today: 110525
Total: 142620848
Forums › The Car › 206 Problems › 206 Gti abs problem *sorted*
rick-gti
PostPosted: Wed May 09, 2012 2:47 am Up
The abs light has just come on, on the gti. I have been working on the car so might have knocked a sensor. Anyway to find which one it could be without getting it code read?
clio 197sport owner
spike_202
PostPosted: Wed May 09, 2012 5:05 am Up
What side have you been working on?
**spike's project**
TEAM:+200bhp
rick-gti
PostPosted: Wed May 09, 2012 5:17 am Up
Ive had both calipers off and driveshafts. Fitted an engine at the weekend into the gti. The sensors have the covers on so i dont think i have hit one with something. Battery was dissconnected for a long time tho.
clio 197sport owner
PostPosted: Wed May 09, 2012 5:25 am Up
Take it up the road and back, if its still on then check the abs rings on the driveshafts, very common.
rick-gti
PostPosted: Wed May 09, 2012 5:28 am Up
The driveshafts came off my other gti, and the abs worked fine. I will have a look at the sensors could be dirty.
clio 197sport owner
PostPosted: Wed May 09, 2012 5:29 am Up
Correct number of teeth for the ABS system fitted on the car?
rick-gti
PostPosted: Wed May 09, 2012 5:30 am Up
Should be the same, both are pre-plex 2000 models. The abs was fine before i swopped engines. Confused
clio 197sport owner
rick-gti
PostPosted: Wed May 09, 2012 6:41 am Up
Sorted now, the fu**ing Cv boot clip i put on the inner driveshaft drivers side had come off (was loose on the shaft) and must have caused the abs light to come on. Removed it and its gone off now. Got to get a new clip now and fit it Mad
clio 197sport owner
spike_202
PostPosted: Wed May 09, 2012 8:21 am Up
Wow Didn't no something like that would turn the abs light on
**spike's project**
TEAM:+200bhp
PostPosted: Wed May 09, 2012 8:26 am Up
We are talking french electrics here. Even something that doesnt conduct electricity and is only linked by being part of the same car can screw some things up with these Razz
