Latest: jackrox1992
Overall: 17186
Online Now [839]:
Visitors: 838
Today: 104619
Total: 147824915
Forums › The Car › 206 Talk › car fix price good or bad?
Forum Index › 206 Talk
Go to page Previous  1, 2
PostPosted: Thu May 10, 2012 5:01 am Up
PeterM wrote:
I once clipped something in the road and smashed the front cat on my 206 1.1 many years ago and they wanted £174 for the front cat and £50 for the front pipe.... I rang up NPA 01670 520111 and got a front cat for £25 and front pipe for £4... trade prices to the public, give them a call
trade price?
most likely they just sell you a tin can as a cat.
PostPosted: Thu May 10, 2012 5:08 am Up
Seabook wrote:
trade price?
+1
PostPosted: Thu May 10, 2012 5:10 am Up
Id rather get a genuine 2nd hand cat if I was on a budget then fit aftermarket crap.
PeterM
PostPosted: Fri May 11, 2012 2:16 am Up
Maybe you should try them before saying they're s**t?
PeterM
PostPosted: Fri May 11, 2012 2:42 am Up
Ive seen enough problems caused by aftermarket parts over the years to know most are just worthless s**te & not even worth the hassel of fitting.
PostPosted: Fri May 11, 2012 2:43 am Up
there is no need to try them if you know what is a cat and how much is the catalyst cost.
i work on metal catalyst and i know how much they cost (trade price with discount of returning any metal waste).
PeterM
PostPosted: Fri May 11, 2012 4:46 am Up
At what point did i mention aftermarket parts? they are genuine parts and failing that blueprint? I've never had a problem with anything from this place and have used them for 10 years.
PeterM
PostPosted: Fri May 11, 2012 6:03 am Up
i am saying that there is no way you can buy a oem cat for 25 quid; even the scrap value is higher than that
PostPosted: Fri May 11, 2012 6:11 am Up
Seabook has a point, I have a buyer who buys all my cats for £45 even small ones on 1.1s regardless of condition (unless totally smashed) so a brand new one for £25 seems too good to be true, it's the catalyst which costs loads you can get cheap other exhaust parts for not much though.
PostPosted: Fri May 11, 2012 6:21 am Up
of course.
check out the palladium price, they are 375GBP per ounce; rhodium is 837GBP per ounce; platinium is 915GBP per ounce.
depending on the size, the precious metal content can range from as little as 0.05 oz to 0.5 oz; there is a reason why cat is expensive.
racing cat. is cheaper because it got less catalyst....
PeterM
PostPosted: Fri May 11, 2012 11:04 am Up
It was a few years ago when i got my front cat for that price, Instead of speculating why dont one of you ring them up and ask for a cat for you car? At least then if the price of a cat has gone up you can say with FACTS rather than mindless speculation?
PeterM
Page 2 of 2
